Sync and text messaging
Old 09-25-2013, 06:41 PM
7sixpack7's Avatar
7sixpack7
7sixpack7 is offline
So after updating Sync in my Super Duty the system no longer receives text messages on the stereo. Before the update if I was paying attention I could hit a button on the screen and the stereo would speak the text message. Now all I get is my phone is not blue tooth compatible with the system. WTH? Anyone else have this happen and can I be fixed?
Thanks,
Phil
Old 09-25-2013, 07:59 PM
senix's Avatar
senix
senix is online now
Received 1,423 Likes on 1,016 Posts
take the phone out of the system and then re-link it.
Old 09-25-2013, 09:45 PM
SavageNFS's Avatar
SavageNFS
SavageNFS is online now
Received 7,120 Likes on 2,231 Posts
re-linking might be known as "pairing" in your phone manual.
Old 09-25-2013, 10:36 PM
7sixpack7's Avatar
7sixpack7
No go! Tried relinking or pairing and no change.
Old 09-25-2013, 10:44 PM
mikethomas's Avatar
mikethomas
mikethomas is offline
What phone do you have? I have never been able to get text messages in my truck. I sat down with the Ford tech and went through it step by step. Un-paired and re-paired my phone and still no luck. I have an iphone 4s. The tech's final response is that it doesn't work with all phones. He also said that there was a change in how the system works from the 11/12's to the 13/14's. Something about the newer systems being software based vs the older systems being hardware based. Not sure what that ment. He also said that the older systems being hardware based were quicker to respond to commands.
Mike
Old 09-26-2013, 08:30 AM
FordIVTteam's Avatar
FordIVTteam
FordIVTteam is offline
Official Ford Rep
Mike
Mike,
This would be important information to have, absolutely. Depending on the make and model of the phone, the SYNC feature compatibility will vary. Here's a current list of test devices: SYNC and Phone Compatibility | SYNC Support | MyFord Touch | Ford.com
There has been some confusion in the past as to why a phone might occasionally render a feature even though it's not listed as compatible. The list classifies a device as compatible after passing several tests to prove that a feature can function reliably and consistently.
7sixpack7, if you find that your phone should fully support text messages, then we can take some troubleshooting a few steps forward - but we would need more details about the phone you're using.
Antonio
Old 09-26-2013, 11:22 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
The update messes with the messaging settings -
Make sure you go back in and set it to "Text to Speech" or however they worded it ---
think it's the last option...
Old 09-26-2013, 07:09 PM
7sixpack7's Avatar
7sixpack7
That was it! It's working now! Thank you!
Old 12-03-2015, 09:49 PM
Celticbhoy's Avatar
Celticbhoy
Celticbhoy is offline
my issue text to speech was working fine, now is not. Called Ford they told me to do a factory reset and then punched in text to speech again after reboot, still no joy called ford. Now they say I have to take it in and my dealer who also could not solve problem will have to work with technician from factory? Goes in tomorrow. Phone is Blackberry.
Old 12-05-2015, 07:18 AM
Celticbhoy's Avatar
Celticbhoy
Dealer could not resolve issue. A little peed off right now. they say they have to research further?
Old 12-05-2015, 07:55 AM
razehm's Avatar
razehm
razehm is offline
Get a new phone, problem solved. DO they even make a blackberry anymore?
Old 12-05-2015, 08:10 AM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
ATT has 3 blackberrys for sale
Old 12-05-2015, 09:42 AM
Celticbhoy's Avatar
Celticbhoy
Believe it or not the Blackberry works better than the iPhone with my sync. I've no choice anyway employer supplied.
Old 12-05-2015, 10:28 AM
FordIVTteam
Official Ford Rep
Hey Celticbhoy,
They may have escalated this to their Technical Support Team. Let me know what they come back with. I'm happy to help where I can.
Whitney
Old 12-05-2015, 11:00 AM
Celticbhoy's Avatar
Celticbhoy
Thanks, will do.
Quick Reply: Sync and text messaging
