88 302 timing
Old Jun 18, 2003 | 11:22 AM
dfawvor's Avatar
dfawvor
Question 88 302 timing
Recently replaced the upper/lower intake manifold gaskets to repair oil leak (this was big job for me...only done oil changes and brakes prior to this). Removed the distributor at the same time. Now the timing is off. How do I set the timing? I have the Chilton manual and know how to use it, but can someone put this process in concise terms I can understand???
Dan
Old Jun 18, 2003 | 06:16 PM
cajunbronco's Avatar
cajunbronco
88 302 timing
Remove the number one spark plug.
Turn the engine over by hand(breaker bar and socket on crankshaft bolt)
Put your finger over the number 1 spark plug hole.When you feel a rush of air coming up stop.
Look at the timing marks on the crank.Now line up the pointer with zero on the scale.
Install distributor with rotor pointing at the number 1 terminal(make a mark on the base with the cap off)
Tighten down the dist bolt.
This will get you close,but you will need to check it with a timing light.BE SURE AND REMOVE THE SPOUT CONNECTOR BEFORE SETTING THE TIMING.The chiltons should show you the location.
CB
Old Jun 18, 2003 | 07:39 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
88 302 timing
Chilton's never exactly showed me mine. I found it by accident. It is the grey connector sittin atop the brake booster in this picture.
Hope this helps you.
Old Jun 18, 2003 | 11:12 PM
steve83's Avatar
steve83
88 302 timing
Jr
Can you post a pic of the wiring harness near your ignition module on the distributor?
Old Jun 19, 2003 | 08:56 AM
dfawvor's Avatar
dfawvor
88 302 timing
Thanks guys. I'll give it a shot this weekend. By the way, I guess if I'm gonna keep asking questions I'd better get a cooler handle than dfawvor!
Old Jun 19, 2003 | 10:33 AM
jrs_big_ford_f150
88 302 timing
Sure can Steve. I will be back in a couple of minutes.
Old Jun 19, 2003 | 10:44 AM
steve83's Avatar
steve83
88 302 timing
The reason I want to see it is that the connector you showed is in the windshield wiper harness, and its wires are NOT colored to be the SPOUT. I don't know what it is, but I think you'll see the actual SPOUT near the ignition module taped into the harness. Its wires are both pink, and there are none on the removable side.
Old Jun 19, 2003 | 10:56 AM
jrs_big_ford_f150
88 302 timing
I got several pictures. First one is the dizzy with its plug sticking out. Second one is the TFI wiring. If you need anymore let me know Steve.
Old Jun 19, 2003 | 12:05 PM
steve83's Avatar
steve83
88 302 timing
In your first pic (of those 2), the SPOUT connector is the gray plastic box in the black connector at the lower R corner of the pic. The TFI is also in that pic. The second one shows the coil connector.
Old Jun 19, 2003 | 01:37 PM
jrs_big_ford_f150
88 302 timing
Boy do I feel stupid. I heard that the SPOUT was on the drivers side firewall and it was a grey connector. Guess I heard wrong. Thank you Steve for correcting my mistake. I owe you one.
Old Jun 19, 2003 | 05:57 PM
Loopie's Avatar
Loopie
88 302 timing
I was wonderin' what you were talking about there JR
Old Jun 19, 2003 | 11:18 PM
mrwizard's Avatar
mrwizard
88 302 timing
Depends on the year for the location of the spout. Mine ('95) is up by the driver's side hood hinge.
Old Jun 19, 2003 | 11:38 PM
steve83's Avatar
steve83
88 302 timing
It's always about that far from the TFI module. In '92, the TFI moved off the distributor (as Jr.'s is) onto the L inner fender (like yours), and the SPOUT naturally followed it.
rmalottwtes30
Aug 17, 2008 11:43 AM
BroncoEx
1978 - 1996 Big Bronco
Mar 23, 2007 05:47 PM
Nitramjr
Escape & Escape Hybrid
May 15, 2006 06:10 AM
shortblock2000
Mar 13, 2006 05:46 AM
KeepOnTruckin
Apr 9, 2002 10:39 PM
