Odd Rattling Sound
Old Sep 24, 2013 | 12:31 PM
bly8397's Avatar
bly8397
Odd Rattling Sound
Truck started making a rattling sound yesterday. It's very sporadic and only while idling. Sounds almost like a socket behind a pulley but I know that is isn't the case. There is a also a rhythm that is sync'd up perfectly with the serpentine belt. Sounds like its coming from the front of the engine. Doesn't happen all the time, but it's annoying and concerning when it does. Any ideas?
Old Sep 24, 2013 | 12:32 PM
bly8397's Avatar
bly8397
Forgot to add that I inspected all the pulleys and the tensioner and everything seemed okay.
Old Sep 24, 2013 | 04:43 PM
diehardstroker's Avatar
diehardstroker
did you loosen the belt and try to wiggle the pulleys?
I had a horrible grinding/rattling noise up front and i looked and looked and couldnt figure it out. i loosened the belt and tried wiggling pulleys and i could move the idler pulley. that one was my culprit. it would make the noise at idle and if i was driving it would make the noise if i came to a stop.
Old Sep 25, 2013 | 06:57 AM
bly8397's Avatar
bly8397
Yeah, I checked that first and all seemed well. My fan clutch has been locked up for a couple weeks now. It's really cooled off here lately so I decided to remove it until I get the replacement. After removing the fan and shroud I can easily access all the pulleys. I made sure everything was tight while in there yesterday. Truck sounds much better now and has a little more umph. The rattling seems to have stopped... It's been intermittent so far. Nothing felt loose but hopefully I took care of the issue. Might have been something on that frozen fan clutch. Never heard of that happening but perhaps. I'll repost here if the rattling returns. Thanks for the input.
Old Sep 25, 2013 | 07:07 AM
petrokiller's Avatar
petrokiller
Waterpump spin smooth while belt was off??
Old Sep 25, 2013 | 11:36 AM
bly8397's Avatar
bly8397
Yep. I just replaced the water pump a couple weeks ago.
Old Sep 25, 2013 | 12:34 PM
Mr. Finch's Avatar
Mr. Finch
do you have a/c, and does it work? I have found ALOT of times hearing that kind of noise with all the pulleys intact it turns out to be the compressor clutch, noise will come and go. If the ac worked, turn it on and see if the compressor actually engages, and if the noise returns or changes when it does engage.
96halfton
Jun 26, 2017 06:21 PM
mattdoc88
May 1, 2015 02:22 PM
TNT
15
Feb 19, 2009 10:47 AM
tps93ranger
1983 - 2012 Ranger & B-Series
Oct 31, 2008 02:19 PM
franklin411
13
Oct 29, 2003 07:30 PM
