95 F150 Help with installing 10.25 sterling rear axle
Received 3,108 Likes
on
As a follow up to this thread here is some more information. I put the axle in about a year ago and the axle is working fine. I had to shorten the driveshaft and get a conversion joint to make the connection. A few other things I had to change were the U-bolts to lager ones I had made at a local semi repair shop. Also, I needed different wheels for the different bolt pattern; I got these with the axle and got some used tires to fit. Last note my truck had a sway bar but it did not fit the new axle (I did not see a change in ride quality). Most everything else was a strait forward swap over.
NeXguy
02-18-2011 02:38 PM
pimpjuice351
10-31-2008 09:24 PM
