Engine suddenly cut off driving, won't start help
Old Sep 23, 2013 | 11:55 AM
danomac1982's Avatar
danomac1982
Well my truck was running great, 1987 f150 efi. Suddenly was driving and the engine just cut off. I tried to start it and the starter sounds fine but it will not fire up. Almost seems like it's getting no fuel? I tried both tanks which both had gas and still didn't work. Is this an obvious problem with the fuel pump maybe? I put in a new starter a month ago and my mechanic put in a used distributor about 8 months ago.
The gas gauges on the dash have been acting wonky since about 2-3 months ago. The meter points to over full until I am very low on gas. Also last month when I filled up the tank I noticed very small amount of gas under my truck, must be a leak somewhere when it's full.
I left a note with my mechanic saying it might be a fuel pump problem and now it's 3 days later. I have no idea what could be taking them this long to figure it out. They said they checked the distributor and got the engine started with "ether" but thought maybe it was out of fuel. WHEN I left a note stating "It could be the fuel pump?" I had jusst gotten gas shortly before the engine cut out.
Does this sound like an obvious problem that anyone could help me deal with? Thank you
Old Sep 23, 2013 | 12:57 PM
Extreme Dimensions's Avatar
Extreme Dimensions
Former Vendor
It does sound like it could be a fuel pump if they are getting it started with starter fluid.
My advice would be to have them check fuel pressure prior to dropping the tanks though.
Old Sep 23, 2013 | 04:01 PM
danomac1982
I asked if they check the fuel pressure and they said they did. Going on the 4th day at the shop and they don't know why it won't fire. I don't get it.
Old Sep 23, 2013 | 04:09 PM
85e150's Avatar
85e150
TFI ignition module is always a suspect when this happens. Test for spark would tell the tale to look there. Since they got it started with starting fluid, it may be intermittent.
You just bought fuel? Where? Receipt? Have they checked filters? Checked fuel for water?
All this stuff is the first hour of diagnosis, not sure why you are out 3 days here......
Old Sep 23, 2013 | 05:00 PM
mary-kate's Avatar
mary-kate
A bad ground for the fuel pumps could cause this intermittent problem (I have an 87 too, guess how I know...). The ground wires for both tanks(pumps and senders)join together and then go to ground-therefore both senders and both pumps would act up at the same time under this condition, which would explain the gauges acting funny. Both fuel pumps going out at the exact same time is almost unheard of, and the connectors on the fuel pumps are easy to get to for electrical testing-time to take it to a different shop.
Old Sep 24, 2013 | 03:04 PM
danomac1982
Thanks I will let them know and if they can't figure it out by tomorrow time to find a new shop. It doesn't seem normal they can't figure it out in 4 days.
Old Oct 6, 2013 | 08:59 AM
Mike4xdriver's Avatar
Mike4xdriver
I had the same thing happen to me. Look at the Fusable links next to the battery and make sure you dont have a corroded one. I had this exact thing happen to me. Replaced a bunch of stuff and then read about this issue and checked it and bingo corroded fusable link. Hope this helps.
Old Oct 12, 2013 | 02:21 AM
USMCJosh's Avatar
USMCJosh
TFI is a common problem on these guys. It'll run for a while then die. The ignition module gets too hot and just quits. That being said, it shouldn't take four days to find out why a motor won't fire.
Old Oct 20, 2013 | 12:33 AM
Big Norm's Avatar
Big Norm
Bad fuel pump
It's a bad fuel pump in tank. I replaced mine on my 1992 F250 300 4.9 over the summer. Afterwards it started and ran like a dream.
Old Oct 26, 2013 | 10:20 AM
Mike4xdriver
Im thinking the shop he took it to would have thought of that Big Norm. I bet its a hidden electrical issue.
norma peters
Jun 6, 2019 09:07 AM
Joel Cassell
Jun 9, 2014 10:19 PM
sundvl76
1997 - 2003 F150
Jan 23, 2013 10:57 PM
Mike58
Modular V10 (6.8l)
33
Jun 6, 2012 02:33 PM
gandalf23
Mar 9, 2012 08:31 PM
