Rough idle.
Old Sep 22, 2013 | 06:45 AM
Codeodd's Avatar
Codeodd
Rough idle.
I have a 1997 explorer xlt 2 wheel drive 4 door. It's got 189,000 miles on it. It's shacks a lot on idle when put in drive. I've replaced a lot of stuff. I've also lost a lot of power. I can put the gas peddle to the floor and still not get enough power.
The shacking feels like it's about the stall out but it doesn't. Oh and there a rear main leak if that helps. Any help would be nice. Thanks
Old Sep 22, 2013 | 01:09 PM
shorod's Avatar
shorod
It sounds like you either have a bad misfire due to the ignition system or a vacuum leak. Is the Check Engine Light (CEL) on and/or have you checked for diagnostic codes? Does the exhaust smell a bit like raw fuel?
It sounds like the first thing to do is give the truck a full tune up and carefully inspect the vacuum lines. If you don't find a bad vacuum line, you might have a leaking intake manifold gasket or PCV elbow which are both pretty common depending on which engine your Explorer has. You don't mention if it's a V-8 or V-6, and if 6 cylinder, which (OHV or SOHC).
-Rod
Old Sep 22, 2013 | 07:14 PM
Codeodd's Avatar
Codeodd
-Rod
It is a 6 cylinder (ohv)
carrellben
Apr 22, 2018 07:46 AM
V8SHO
Jan 8, 2016 03:54 PM
BigBodySage
Jun 6, 2013 10:56 AM
southsidej
May 30, 2005 06:22 PM
Demicon
Feb 23, 2005 01:39 AM
