90 F-350 Engine Temp
I have a 90 F-350 with a 7.3 with a manual temp gauge. Running no load the A/C off or on it runs about 190 deg. Pulling a 7500 lb trailer its running 205 -210 A/C off. Ive asked several people how hot the truck should run no one seems to know.
Hmmmmm anyone?
Thanks
David
Hmmmmm anyone?
Thanks
David
Hello, Welcome to FTE!
Your truck will always run hotter with a load. Your engine temperature is a balancing act between heat production, radiator capacity, coolant flow, and ambient temperature. The thermostat just sets a minimum temperature.
That seems to be a real good temperature, I would be happy
