Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
single or double flare tool?
Old Jun 17, 2003 | 10:21 PM
stubborn1's Avatar
stubborn1
Hi,
I don't know a whole lot about flare tools and am wondering if I can get by with a single flare tool or if I need to spend extra cash for a double flare tool. I will primarily be flaring replacement steel transmission and brake lines.
Does the high pressure of the brake lines require a double flare?
Thanks for the help.
Old Jun 18, 2003 | 12:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Double flare tool is required for all high pressure lines; brakes, hydraulics, power steering, transmission...
Besides, the first part of the double flare operation makes a neat retaining bulge for rubber fuel lines and hoses.
Old Jun 18, 2003 | 06:56 AM
sosotwo's Avatar
sosotwo
when you buy a flareing tool it should have dies in it for diferant size of steel line use the die for single flare then take out die run your tool down again for a double flare
Old Jun 18, 2003 | 04:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Every kit should have directions. Practice on a scrap piece of tubing a few times b4 you try the real thing.
Old Jun 18, 2003 | 07:38 PM
angus's Avatar
angus
Don't bother with a cheap kit. The Ridgid #345 worked for me; I tried a Lisle kit first but it couldn't make a usable 3/16" double flare.
Old Jun 20, 2003 | 11:51 PM
jagabom's Avatar
jagabom
Double flare. You don't want to go back and fix it again.
Jim
