Recommend setup?
Old Sep 20, 2013 | 07:14 AM
lostru's Avatar
lostru
Recommend setup?
I currently own a 2006 F350 srw lwb crew cab. I'm looking to see what the recomended setup is to pull a 31ft camper that is a bumper pull. Short trip maybe 200miles round trip. Swaybar, no swaybar, and type of hitch. It has the off road package and the 20" wheel option. Thank you ahead of time.
Old Sep 20, 2013 | 12:52 PM
MX727's Avatar
MX727
If you have Camper Package, then you have sway bar. As far as hitch, just get the right drop. Depending on tongue weight, you may or may not need load leveling hitch.
Old Sep 20, 2013 | 01:19 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
With a 30' trailer (RV) you NEED a load leveling hitch... you don't need to be lighting up the tree tops while driving at night. You'll also want a anti-sway device to stop 18 wheelers from whipping you off the road!
Old Sep 20, 2013 | 02:20 PM
senix's Avatar
senix
Your 2006 should have the factory trailer brake controller I'd imagine..if not then don't forget that or an aftermarket TBC.
Old Sep 20, 2013 | 03:57 PM
lostru's Avatar
lostru
Tongue weight dry is 800. So I think the weight will be good as long as stated above, the drop is right. Now to get a hitch. Tbc was standard on my girl so that's covered.
Old Sep 20, 2013 | 08:11 PM
RV_Tech's Avatar
RV_Tech
Trailer weight is?
Steve
Old Sep 20, 2013 | 10:13 PM
lostru's Avatar
lostru
7900 dry. Add all your goodies and im figuring 10, 500 to 11, 500 on the heavy side.
Old Sep 20, 2013 | 10:28 PM
RV_Tech's Avatar
RV_Tech
Always a good idea to weigh so you have actual weights.
Steve
Old Sep 21, 2013 | 06:32 AM
senix's Avatar
senix
Use the "wet" or GVW of the trailer and then figure 10-15% for tongue weight.
Old Sep 25, 2013 | 02:01 PM
RA31925's Avatar
RA31925
I'm learning that the response is "when in doubt, use a weight distribution system" ... they're cheap insurance.
Old Oct 2, 2013 | 07:28 AM
lostru's Avatar
lostru
Pulled the TT yesterday without the weight distribution hitch or a sway control. Pulled like a champ. I can see where the sway control would help but I finally aired up the rear tires to the required 75psi and figure that will take most if not all sway out. It might help that the tanks are finally dumped on it too. All but the fresh water was 3/4 full. No it wasn't my doing. Trying to help a Military Wife with her husband deployed.
Old Oct 2, 2013 | 08:10 AM
RV_Tech's Avatar
RV_Tech
The crazy thing about sway control and WD is you never need it until you do.
Steve
Old Oct 2, 2013 | 08:19 AM
lostru's Avatar
lostru
Very good point. What would I need to do if the camper was never outfitted for the WD hitch or sway control.
Old Oct 2, 2013 | 09:27 AM
r2millers's Avatar
r2millers
Any unit is easily attached to the trailer. The hitch assembly is heavier and allows for the bars to be attached.
Since you are only going a short distance, see if U Haul or someplace similar rents them.
Wonder why they don't have one already on this unit?
Agree with others, Don't drive without a HD with 10k plus!
Old Oct 2, 2013 | 05:45 PM
MisterCMK's Avatar
MisterCMK
Originally Posted by MX727
If you have FX4, then you already have sway bar. As far as hitch, just get the right drop. Depending on tongue weight, you may or may not need load leveling hitch.
Are you talking about the rear sway bar? If so, the FX4 package does not mean you have the sway bar.
