1961 Ford F100 Electrical Problems
Old Sep 22, 2013 | 10:08 AM
sixtyonef100's Avatar
sixtyonef100
Will do. Now when you said grounded the tailights etc to the bed then to the frame I just need to run a ground wire from the taillight/running light socket or just the bezel?
Old Sep 22, 2013 | 11:06 AM
schoo's Avatar
schoo
The light fixture has two bolts out the back they are the ground you need clean metal contact through out the rest of the circuit to ground (frame rail that neg bat connects to)use no-ox at connections
Old Sep 22, 2013 | 11:29 AM
schoo's Avatar
schoo
I just looked back thru this thread and I did see any pic??
Old Sep 22, 2013 | 01:09 PM
arctic y block's Avatar
arctic y block
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Sep 22, 2013 | 02:32 PM
sixtyonef100
I will post a picture of my fuse block. Thanks for the help.
Old Sep 24, 2013 | 06:38 PM
sixtyonef100
[IMG][/IMG]
Old Sep 24, 2013 | 06:40 PM
sixtyonef100
That wire that is bare on the end is attached the the running lights and I can't seem to figure out where it goes. Same with that blue one with a purple/red stripe.
Old Sep 24, 2013 | 06:54 PM
hiball3985's Avatar
hiball3985
The blue with red stripe is usually for the dash lights, the ones that light the gauges.
Old Sep 24, 2013 | 06:57 PM
sixtyonef100
Up at the gauges there is one just like that thats disconnected. Is it possible that my truck doesn't have that feature?
Old Sep 24, 2013 | 07:03 PM
hiball3985's Avatar
hiball3985
No, they all come with dash lights. What do you mean by disconnected? It should probably be connected to the one hanging from your switch. Unless someone disconnected it for some reason like a short or the headlight switch rheostat is bad. Why don't you get a wiring diagram?
Old Sep 24, 2013 | 07:54 PM
sixtyonef100
At the gauge cluster, all the plugs are filled by wires, but this one is just left hanging and it doesn't look as if it was ever plugged in. I know thats not a real problem in the whole scheme of things, as my generator light comes on and I know for a fact that the battery doesn't charge.
Old Sep 26, 2013 | 12:29 PM
sixtyonef100
Alright I replaced the switch for the headlights and the running lights and found that the black wire next to the red wire is the picture above is faulty. By jiggling that wire the running lights will flash on and off when the switch is activated.
Old Sep 26, 2013 | 07:59 PM
  #28
hiball3985's Avatar
hiball3985
I believe the black wire is the one that goes to the tail lights?
Old Sep 27, 2013 | 09:02 AM
  #29
sixtyonef100
It lights up the tail lights and the running lights when I get it to receive power. The socket at the switch is faulty so I will have to solder something up that will make it work. I also don't have a rear left blinker or blinkers when my head lights are on for some reason but I believe I'm closer to finding the issue.
Melonmuziq
May 25, 2018 02:33 PM
lakecityg
Electrical Systems/Wiring
34
Jan 26, 2015 05:27 PM
civiltech
Mar 28, 2011 12:39 AM
mikeescott
Jan 19, 2005 10:03 PM
packrat_1954
Nov 7, 2001 11:29 AM
