Transfer Case?
Old Sep 15, 2013 | 07:46 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Transfer Case?
I have a rear driveline vibration, after replacing the u-joints and still vibrating. I noticed I can move the transfer case 1/2" in all directions! Upon further inspection I noticed the adaptor between the transmission is cracked in a few places! Question is that part in front of the transfer case and behind the transmission called an adapter plate?
Old Sep 15, 2013 | 08:29 PM
hav24wheel's Avatar
hav24wheel
Yes alot of people call it that.
Old Sep 15, 2013 | 09:05 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Extension housing. Tailshaft housing, transfer case adapter...
Old Sep 16, 2013 | 06:09 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Thanks for the answer, has anybody changed it out? looks like drive shafts/transfer case then adapter plate. Does the shaft from the transmission go directly into the transfer case? Gasket on the transmission & new transmission mount. It looks like there is a lot of weight hanging past the last mount! Like the transfer case & adapter/extension housing!
Old Sep 16, 2013 | 03:27 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
bump any body worked on one?
Old Sep 16, 2013 | 03:44 PM
Archion's Avatar
Archion
I've pulled a few off other vehicles before. Are you leaking trans fluid from there or is it not cracked all the way through? I can't remember if that's a wet extension housing or not. Once you pull the drive shafts and transfer case, the extension housing should unbolt and slip off. There may be gaskets or o-rings.
Old Sep 16, 2013 | 08:21 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
I think its a dry type. I was worried about the weight. Going to use a friends hoist and tranny jacks
Old Sep 16, 2013 | 08:58 PM
Bigpipes 35's Avatar
Bigpipes 35
Any pics of the issue ?
Old Sep 16, 2013 | 09:08 PM
Archion's Avatar
Archion
It's gonna weigh about as much as a stick shift trans. A trans jack and you'll be fine.
Old Sep 16, 2013 | 09:42 PM
sccamper's Avatar
sccamper
The output shaft of trans slips right into the input of transfer case. 1 or 2 dowel pins help line up transfer case to trans. I dont know if anything has to come off the output shaft to get the extension housing off. Used to have to pull speedo gears off some trucks. I dont know on the EX.
Old Sep 16, 2013 | 11:41 PM
EXv10's Avatar
EXv10
Scratch those first two.
Old Sep 16, 2013 | 11:42 PM
EXv10's Avatar
EXv10
Thanks for the answer,has anybody changed it out? looks like drive shafts/transfer case then adapter plate. Does the shaft from the transmission go directly into the transfer case? Gasket on the transmission & new transmission mount. It looks like there is a lot of weight hanging past the last mount! Like the transfer case & adapter/extension housing!
No they just changed it.
Old Sep 17, 2013 | 01:49 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
My transmission guy said that a bad u-joint may have caused the adapter to break. I did just replace the back u joint with a OEM spicer (that i now think are the best). Im having the trasmission guy replace it labor only on friday. Thank you FTE forum! for the tousley discount, parts are less than $200.00
Old Sep 17, 2013 | 07:53 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Old Sep 17, 2013 | 08:00 PM
Bigpipes 35
Yikes ... I hope that is a isolated incident.. Thx for the pics..
