couple days ago my check engine light came on, but then went off again.. got home and noticed i was low in water.. added a gallon to top it off.
today.. 3 days later , i was low again.. about a gallon. i only drove about 80 mls since last fill of water.
i noticed a small drip of antifreeze on one of the lower hoses.. which are new.. but nothing else.. no leaks, no spot from water in carport, oil is clean and truck does not smoke white . ?? where the heck is the water going..floor inside is dry too...
btw now oil / fule in water either
Seen it many times before.you cant see the weephole..when it drips the pulley and fan disperses it so finely you may not see ut drip till the dam brakes.
dont take my word for it though.
