1981 F-350 C6
1981 F-350 C6
My tranny died. What years and engine C6 will fit my 81 F-350 2wd 4.9 litre? I know it has to be from a 2wd. I think a 302 and maybe a 351 will work. I do have a 4wd C6, but was told changing the output shaft is a big job. How hard is that to do? I have worked on vehicles a bit, but have never been inside an automatic yet. Any help is appreciated. Thank you.
Thanks! it sounds like the rebuild is more than I want to try right now (I also no have no place inside to do the work).
Will a C6 from any year work. I think I heard the ones from the 1970's were different. If so, what years will work. Will a tranny from a car work, or are they different? Thank you!
Generally any small block style will work from late 70's up. Keep in mind extension housing length, is yours bolt on yoke or slip yoke as those are different lengths. Also manual levers are different from cars and trucks as well. Those can be changed without too much trouble. Not a bad tranny to learn how to start rebuilding, very basic, and parts are cheap. Good luck!
Ky_Madman
05-31-2010 11:15 AM
1984F150SB
05-25-2009 05:43 PM
tomas428
03-27-2006 06:41 PM
Boss50
06-29-2005 05:36 PM
