1987 Ford E-150 problems
Old Jun 17, 2003 | 02:46 PM
jbsgirl3's Avatar
jbsgirl3
Help! My son's 1987 Ford E-150 van was running perfectly and just shut off and won't start. We have checked the obvious. Anyone know of any quirks or have any suggestions. Desperate!
Thank you!
Old Jun 17, 2003 | 03:27 PM
Mil1ion's Avatar
Mil1ion
Please state what the obvious is !
This helps FTE users to determine what the problem could be.
An engine takes Air,Fuel,Spark to run.
Which one are you missing Fuel, Or Spark ?
Old Jun 17, 2003 | 09:56 PM
c96drumm's Avatar
c96drumm
I've had an ignition module fail like that. Sometimes they'll work again for awhile after cooling off, sometimes not. Check for spark. Any codes? Fuel pump turning on for a second or so after turning the key to "on"?
A parts store can probably test the ignition module for you. That's the first thing I'd check.
