Aerostar Ford Aerostar
PCV Valve??
Old Jun 17, 2003 | 02:23 PM
agelder's Avatar
agelder
PCV Valve??
Can a bad PCV valve contribute to a rough idle? My mechanic is telling me that that is part of the problem, but I can't logically make the connection as to why. Any opinions (for engine info, see sig)?
Old Jun 17, 2003 | 06:00 PM
Mikeman's Avatar
Mikeman
PCV Valve??
According to the shop manual it can. I've never noticed a difference when putting a new one on, perhaps because the old one hadn't failed. I suppose it would have to either be plugged up or wide open to have any effect. For $3, I don't worrry as to whether it's bad or not, I just replace it regularly.
Old Jun 17, 2003 | 10:30 PM
MO51's Avatar
MO51
PCV Valve??
Yes it can affect performance, at least on my '96 4.0. It won't idle well, or get good mileage, with a "bad" one. This includes a brand new Fram replacement. Go for the OEM Ford valve. It fits, apparently, and it solved my rough idle problem inexpensively.
Old Jun 18, 2003 | 08:18 AM
agelder's Avatar
agelder
PCV Valve??
I went and bought a Purolator at Autozone yesterday, hopefully that will help. Thanks!
Old Jun 19, 2003 | 01:26 PM
agelder's Avatar
agelder
PCV Valve??
Replaced it at lunch, didn't do any good in helping me keep from stalling when I fire the van up, but the other valve didn't rattle at all when I took it out. Still worth th $3 or so I paid for it I'll bet.
Old Jun 21, 2003 | 11:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
PCV Valve??
Just because the PCV rattles does not mean it is good. The valve and spring wears internally and the valves loose their metering ability. Replace annually...
Fram == Cheap
Old Jun 22, 2003 | 05:35 AM
agelder's Avatar
agelder
PCV Valve??
I went purolator, Ive had better luck with them than fram.
