1978 - 1996 Big Bronco
run-on?
Old Jun 17, 2003 | 01:37 PM
56efffie's Avatar
56efffie
run-on?
What my be the cause of the motor run-on when you shut it down. It does this for about 10 seconds when the motor is fully warmed up. 1978 with a 400m
Old Jun 17, 2003 | 02:50 PM
mrwizard's Avatar
mrwizard
run-on?
Have you checked the timing?
Old Jun 17, 2003 | 05:00 PM
JBronco's Avatar
JBronco
run-on?
Timing off, bad gas (or too low octane gas), or the engine is overheating.
Old Jun 17, 2003 | 07:42 PM
SouthPCraz's Avatar
SouthPCraz
run-on?
my 78 400 did the same thing but worse it would stop dieseling unless i let out the clutch in geer (thats bad on it) so i just played around with the adjustment screwes on my carb a little bit and tuned it down and it wont diesel anymore but sometimes it will if i dont tap the gas pedal and make the idle go down a little before i shut it off
Old Jun 17, 2003 | 07:56 PM
Gwrenchplus's Avatar
Gwrenchplus
run-on?
on carb engines carbon build up on the valves would cause your problem after running and getting hot the carbon would get hot enough to fire the cylinders. i know this will sound crazy to everyone but you could pour a 12 oz can of water thur the carb to clean the valves. you have to keep the engine at a high rpm and pour the water slow but it will do the job. i have done my 96 f150 this way i used a sprayer it works good.but i would check my timing first and for bad gas if the timing and gas are ok the water will do the trick. my father worked for a auto dealer ship this is where i leaned to do this they done this real often. but like i said keep the rpms up and pour it slow.
Upper Case Edited Out by FTE
Old Jun 18, 2003 | 04:17 PM
JBronco's Avatar
JBronco
run-on?
Yeah, GW has an old trick there. We used to do that, although I never tried it for a run-on problem. They say that transmission fluid works too. I remember once, I had someone keep my car running while I poured a quart of tranny fluid in the carb! I don't know if it did anything, but it sure made a lot of smoke!
Old Jun 18, 2003 | 08:34 PM
Gwrenchplus
run-on?
transmission fuild works but it takes more of it and having to put up with all the smoke but water is best. carbon will also cause a engine to ping like the timing is off when under a load.
Old Jun 20, 2003 | 11:52 AM
56efffie's Avatar
56efffie
run-on?
Thanks for the responses! I will start with the timing and go from there, I have a feeling that is probably the cause.
Old Jun 20, 2003 | 04:04 PM
bronco351's Avatar
bronco351
run-on?
I have an easy solution. Get that engine up to red line. Drive it hard like that for a day!! That will always shoot that carbon out of the tailpipe.
No, seriously. When I bought my 1990 Bronco it had sat for a long time in the garage. It still had the original engine when I bought it. I did replace it for a bigger one later on though!! $8,000 worth of big engine.
Anyway. I put the truck in park. I ran the RPM close to 5500, for about 2 seconds!! I did this three or four times. When I got out of the truck. The tail pipe had shot out a bunch of black carbon chips!! It ran better after i did that!! That's my 2 cents!
Old Jun 20, 2003 | 09:31 PM
thelonerangerxlt's Avatar
thelonerangerxlt
run-on?
Shane, your 78 should have had an idle control solenoid on it from the factory. It allowed for a normal idle when the engine was running, and then closed the throttle when the key was switched off. This prevented the run-on.
If yours is gone, you can get another one at a parts yard. Another solution would be to advance the timing slightly (thereby reducing the throttle opening at idle), and leaning out the idle mixture screws as much as possible.
