Dash lights, power windows, turn signals stopped working
Ok I have a 2004 F250 Crew Cab 4x4. The tow haul wasn't working so I took the column cover off and found that problem and fixed it. Next problem that came up is the turn signals stopped working. When I pulled and ignition switch out I some how turned the hazards on and noticed only the left side turn signal light was coming on. I found a post were someone replaced the relay for the hazards and started working. So I took my front panel off to get to the relay. After unplugging the radio, light switch, 4x4 selector switch, reverse sensor, and cigarette plug now my dash light are not working along with intermittent wipers, power locks, and power windows.
I could use a little help in what I need to look for. Been checking fuses and all seem fine.
tylers65
01-26-2014 03:10 PM
Izera
1997 - 2003 F150
08-22-2013 03:14 PM
Fishytruck
1999 to 2016 Super Duty
09-16-2011 09:42 PM
82f3504x4
04-17-2008 02:54 PM
