360 Dipstick Tube Issues
Old Sep 11, 2013 | 07:30 PM
Austy's Avatar
Austy
Question 360 Dipstick Tube Issues
Hey y'all, my dipstick tube sprung a leak at the base recently so I went and bought a nice new chrome one to replace it with since I already had to take it off, but I found that neither the one I took off or the one I bought had an o-ring. Is that my problem? '72 F-250 360. Thanks!
Old Sep 11, 2013 | 08:01 PM
jim collins's Avatar
jim collins
I'v never seen one with a O-ring , It should be a tight fit but some of the new ones are not. I used a little sealer around one that was real loose.
Old Sep 11, 2013 | 08:48 PM
Jdeshler's Avatar
Jdeshler
I'v never been lucky enough to get one off without breaking it off the block .... Jim is right it should be a snug fit with no gasket or O ring.. you can use some jb weld around it to ease you're mind
Old Sep 11, 2013 | 09:01 PM
Austy's Avatar
Austy
Thumbs up
Awesome! Thanks guys!
Old Sep 12, 2013 | 06:21 AM
jim collins
The chrome reproduction ones are the loose fitting ones . Some are to short or long so you need to check that out before using it. I have one in my 302 i had to cut the top of the tube off to make it read correct . It comes up out of the engine when i check oil now so i need to seal it too .
Old Sep 12, 2013 | 09:23 AM
MIKES 68 F100's Avatar
MIKES 68 F100
just swedge it a little so it fits tight , you can use a anything with a taper if you don't have a swedge tool .
Old Sep 12, 2013 | 07:13 PM
Austy's Avatar
Austy
Well it's already tapered, so that should be ok. And as for the right length, it's only 1/4 inch off the original. Little custom notch in the stick and we're a-ok.
TWODOGS522001
Jul 10, 2023 07:15 PM
daltonjamesadams
Dec 18, 2016 06:25 AM
Johnny Be Cool
Feb 14, 2015 08:17 AM
PsD007.3
Nov 13, 2010 03:06 PM
xericx
Jul 30, 2002 12:10 AM
