Sponsored by: Real Truck
Ford F250 Brake problem
Old Sep 11, 2013 | 05:46 PM
Rick Kelley Jr's Avatar
Rick Kelley Jr
I have a 2002 Ford F250 Superduty with a 7.3 diesel. Brakes started sticking on it. I replaced all the calipers cause the boots were starting to crack but not leaking. All four brakes are still sticking. I can drive a little ways and then the brake peddle feels funny and they start dragging all four. I can loosen the bleeder and brake fluid will spray out and release the brakes for awhile. I am at a lose.
Old Sep 11, 2013 | 05:50 PM
WADE MMT/PSD's Avatar
WADE MMT/PSD
Former Vendor
First thought, did you replace the slide pins as well, when you replaced the calipers?
Old Sep 11, 2013 | 06:01 PM
Rick Kelley Jr
yes I replaced everything.
Old Sep 11, 2013 | 06:23 PM
RBlac's Avatar
RBlac
This may be a dumb question, but did you grease the slidepins? I imagine even a little heat will bind those up w/o grease there.
Old Sep 11, 2013 | 06:24 PM
jetjockey99's Avatar
jetjockey99
if the brakes release after cracking a bleeder, you have a master cylinder or possibly a booster problem. Next time they stick, loosen the bolts that hold the master to the booster without cracking a bleeder, about an 1/8 of an inch, if that also releases the brakes then either the booster or pedal is not fully releasing or is stuck partially applied, if that doesn't help and cracking a bleeder does I would replace the master cylinder and make sure you check the push rod adjustment
srpservices
Oct 20, 2013 09:01 AM
tdorval
Jun 9, 2011 11:16 AM
1997fordf2504.6L
1997 - 2003 F150
33
Sep 12, 2010 08:17 PM
JLD42
Aug 24, 2008 11:22 PM
randymc
Feb 24, 2004 08:20 PM
