1962 shifting problems
Old Sep 11, 2013 | 01:24 AM
hues's Avatar
hues
Hi everyone
I've just purchased a 62 f100 step side and am new to this forum, I'll try posting some pictures this week... I've always had a classic ford and still do have a 65 falcon which I am currently restoring.
I found this forum whilst trying to solve my shifting issue. when I try to shift either in 1st or reverse it wants to grind the gears. at first there was no issue with either, then first started to grind and now reverse. I've adjusted the clutch and it seems to be working properly, she shifts into 2nd adn third very well and feels strong... I did notice that when i push in the clutch and coast while still in first it sounds like it's still partially engaged (making a whirling type of noise?). though it doesn't seem to have the issue all the time it does happen most of the time. to cut down on the grinding i've found that shifting into gear very slowly helps quite a bit. while researching it sounds like i need a new synchronizer ring but i wanted to be sure before i started pulling the tranny or anything
please let me know what you guys think
thanks
Old Sep 11, 2013 | 08:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hues
I've just purchased a 1962 F100 Flareside (step side: Chevrolet) and am new to this forum, I'll try posting some pictures this week.
I've always had a classic ford and still do have a 65 Falcon which I am currently restoring.
I found this forum whilst trying to solve my shifting issue. when I try to shift either into 1st or reverse it wants to grind the gears.
As it should, as it's a 1962. The only way to downshift into 1st without grinding, is by double clutching.
Welcome to FTE
1963: First year for Ford type 3.03 3 speed manual all (1st/2nd/3rd) syncromesh manual transmission in F100/250's & misc Passenger Cars.
1962 and earlier have a non syncro (crash) 1st gear as do 1961/67 144/170/200 I-6 Passenger Cars with 2.77 trans (if your '65 Falcon is an I-6, it has the 2.77 trans, if a 289, the 3.03 trans).
At the bottom of the steering column underneath the hood are the two manual control selector levers that the shift rods from the trans attach to.
In each one of these levers is a bushing and insulator. The bushings wear, the shift lever binds up.
C3TZ-7343-A .. Bushing/Insulator Kit (one kit does both levers) ~ 1961/64 F100/250 2WD / Obsolete
NOS ONLY in San Jose CA has 2 = 800-667-6659.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 38 = 800-476-9653.
Old Sep 13, 2013 | 12:29 AM
hues's Avatar
hues
Thanks NumberDummy I've ordered the bushings hopefully that solves my issue! I've tried the standard immediate solutions first (adjusting the clutch and pumping the clutch) just to cover everything i was going to change the tranny fluid as well.
appreciate the help!
the whirling/whining noise when i push the clutch in first... would this be caused by the worn out bushings as well?
Old Sep 13, 2013 | 12:51 AM
NumberDummy
The whirling/whining noise when i push the clutch in first... would this be caused by the worn out bushings as well?
Nope.
The clutch T/O (throwout) bearing is the cause, here's a pic of the little charmer (7580). Bearing is pressed onto T/O bearing collar (7561).
Original collar came with a zerk (grease) fitting, but in 1963, Ford introduced "Lifetime Lubrication" removed the zerk fitting, installed a rubber plug in its place.
Replacement parts thereafter came with rubber plugs. The same scenario also applies to zerk fittings in spindles, tie rod and tie rods ends, draglink and u-joints.
'Course, this Lifetime Lubrication wheeze was really FoMoCo's method of selling more parts, as the warranty period back then was 2 years/24,000 miles, whichever occurred first.
After the warranty period expired, the grease began to dry out, parts soon wore out. Some Ford dealer and gas station lube techs, private owners removed the plugs, installed zerk fittings.
gogreenwave
Nov 1, 2014 10:35 PM
Harypitts57
23
Apr 20, 2014 02:05 PM
D & D
Oct 20, 2013 07:03 PM
josefis
Jun 2, 2009 09:07 AM
BZNSRAT
Nov 4, 2008 05:54 AM
