Sponsored by: Real Truck
Which beds will fit?
Old Oct 20, 2021 | 03:38 PM
nydiver's Avatar
nydiver
Bolts on, body lines don't match up, and the wheel wells are visually obvious that they're different. No one will be fooled that its mismatched and *******ized.
Old Jan 16, 2022 | 08:27 PM
JPunchjr's Avatar
JPunchjr
Just a question
so will a f250 bed fit a f150 97-03
looking for new bed like 250 better
Originally Posted by rollerstud98
Not only are the frames different, but the shape and size of bed is different as well. Now to confuse things a little, F150 tailgates from '97-03 will fit directly on to superduty trucks up to 07. From 97-99 there was an F250 in the F150 body style that is not a superduty. More confusion.
Old Jan 17, 2022 | 01:10 PM
jade97's Avatar
jade97
Not an F250 Super Duty Bed.
Old Jan 17, 2022 | 02:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
97 to 03 F250 LD bed is the same. 250 superduty bed is completely different and will not work.
Old May 8, 2022 | 05:52 PM
Build it's Avatar
Build it
I have a 1999 f350 7.3 power stroke 2wd dually crew cab that I bought that had a wooden flatbed on it and I bought a new 8' take aluminum take off bed 2017 or newer but it is way to different to fit let alone bolt up and it is also 11" to one foot (12") short. Were the older beds actually 9'? Can I even get a bed to fit or does it have to be some type of utility/flat bed? Thanks
Old May 9, 2022 | 04:34 AM
tjc transport
i ain't rite
pickups were either 6.5, or 8 foot. cab chassis duallys could be anywhere from 9 foot to 14 foot.
Old May 9, 2022 | 09:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is your truck a pickup or a chassis/cab truck?
Also, the 2017+ beds will not bolt directly to a 1999-2016 pickup frame. It can be made to work, but a GMC bed could also be made to work.
Old May 9, 2022 | 10:57 AM
Build it's Avatar
Build it
Ya if you use 10% factory bed and 90% fab but then what use it to spend the price for a full bed and only use 10%........I have been doing some digging and from what I have found my vin number W36 refers to crew cab standard bed and not cab and chassis, so that means I should be able to bolt up a 1999-2016 bed...I heard that somewhere along the line the wheel wells do not line up perfectly but will work. Now the hard part trying to find a suitable bed that is not rusty. I do have an additional question though. Does anyone know if the tailgate from a 2017 and newer bed will fit the older beds?
Old May 9, 2022 | 11:55 AM
redford's Avatar
redford
Correct. 1999-2016 beds will bolt in.
No, a 2017+ tailgate will not fit.
Old May 9, 2022 | 03:40 PM
Build it's Avatar
Build it
Thanks for confirmation. Now it seems nobody makes a puck base mounting system to fit the older trucks either....
Old May 10, 2022 | 10:05 PM
Build it's Avatar
Build it
As it turns out my truck is not a dually its a cab and chassis. 34" straight outside frame rails, 60" cab to rear axle, rear center fuel tank and 9' long. Found this all out when I went to get a truck bed...turns out I though I bought a fully skirted cab and chassis flatbed. Fits perfect.....Live and learn.
Old Apr 1, 2023 | 06:29 AM
robb1320's Avatar
robb1320
1st Gear
There was a dually with a 6.5 bed!
Old Apr 1, 2023 | 08:34 AM
  #28
tjc transport
i ain't rite
dually pickup. NOT a cab chassis dually.
1L243
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Feb 10, 2017 07:30 PM
sheriff1
Apr 29, 2014 06:28 PM
josephlynch2
Aug 23, 2009 09:07 PM
xr75kid
Apr 28, 2006 11:06 AM
cjcathey2002
Oct 26, 2005 11:16 PM
