C-6 Question
Old Sep 9, 2013 | 02:31 PM
Corkwheats's Avatar
Corkwheats
C-6 Question
Hey Guys,
I'm taking the big plunge, and swapping out my 360 for a 390 in my 71 Ranger XLT. With the 4 Barrel (Holley 600), Intake, Cam, Head Job, and Headers we are looking at approx. 325 H.P. and 475 Torque.
I have a C-6 in it that has never missed a beat, so am not going to fix it (or change it) if it isn't broke. But, I've often heard that the C-6 is a "power robbing" transmission. I'm not overly concerned about this, but basically, why is this? Is it just because it's not a manual transmission?
Also, is there anything that can be done to "beef up" or add to the performance of the C-6? I've heard of shift kits and stall converters, but I will have a fairly mild cam (designed more for torque). The truck is going to be used on the farm here for pulling hay wagons, and hauling stuff.
Is it basically that the C-6 is tough and lasts long, but just isn't made for racing? If so, I can live with that.
Thanks for any opinions.
Bob
Old Sep 9, 2013 | 02:55 PM
HIO Silver's Avatar
HIO Silver
Automatic transmission are inherently less efficieny than a manual trans. The reason is that they are based on a low pressure fluid medium and moving the (pump) fluid to impart a mechanical advantage (torque converter). This results in parasitic energy loss due to heat generation and fluid dynamics.
Change the ATF and filter , keep 'er cool, and she'll serve ya well.
Old Sep 9, 2013 | 03:21 PM
MIKES 68 F100's Avatar
MIKES 68 F100
I kept my stock c6 when i added my 390,
no issues so far and i have more hp and tq
do your self a favor and replace the front tranny seal while you got the motor out . 5minute job , don't forget to lube the seal with some fluid too.
Old Sep 9, 2013 | 03:23 PM
Corkwheats's Avatar
Corkwheats
Thanks. That's one of the 1st things I did with the truck (Oil Change & ATF Change - Type F). I'm sure it will be fine for my purposes. I'm much more concerned with longevity than performance, anyway. This puppy is probably gonna have 1500 miles a year put on it, so it will probably out live me.
Bob
Old Sep 9, 2013 | 03:47 PM
jim collins's Avatar
jim collins
C/6s are behind 460s , good strong auto trany. Keep the fluid up and clean , don't overheat it and it will last a long time . If you do a lot of heavy pulling or hauling then you can add an extra transmission cooler . Heat is the killer of auto tranys.
Old Sep 9, 2013 | 03:55 PM
Corkwheats's Avatar
Corkwheats
Yep - the front seal is definitely getting replaced. Good point.
Old Sep 9, 2013 | 03:59 PM
Corkwheats's Avatar
Corkwheats
An extra transmission cooler, eh? I wasn't aware of that. But, up here in the Northwoods of Michigan's Upper Peninsula I guess we don't think about over heating much
Bob
Old Sep 9, 2013 | 09:35 PM
carchub's Avatar
carchub
Bob
Sorry I don't mean to hijack or anything, but when you do a fluid change on the C6, how much ATF is needed to refill it? The manual I read (Chilton) says "Add 3 quarts of Type F Automatic Transmission Fluid." ......that seems like way too little to me...I mean when I got my pickup the PO told me "I topped off all the fluids," but the tranny was dry (figures), so I refilled it and it has taken about 3-4 quarts. I thought maybe there was at least SOME fluid still in there.
tl;dr: How many quarts of ATF does it take to fill up a C6 after a fluid change?
Old Sep 9, 2013 | 10:11 PM
ilbiker's Avatar
ilbiker
Did a pan gasket replacement and changed the filter when i was in there. It dropped almost 2 gallons of fluid?? A lot more than the 3 qts required.
Old Sep 9, 2013 | 10:16 PM
bradb2230's Avatar
bradb2230
Of all the transmissions out there, the C6 is simple to rebuild and modifications for it seem limitless. The C6 has seen service behind so many different engines, and both cars and trucks, that there are a huge selection of aftermarket parts.
C4 C6 Performance Transmission from PATC, C6 Transmission
This is one of the sites I have been looking at for parts on my C6, and you will notice that they have a package that will double the amount of clutches and steels in your tranny, thus increasing the amount of pulling power behind the engine. There is an advantage of rebuilding a transmission that "Isn't broken." First is you can be sure that the "Hard Parts" are going to still be in good shape. These parts can drive the cost of an overhaul to the sky. Doing a "soft overhaul" replaces parts that wear out including clutches, bearings, steels, thrust washers, bands and modulators. It will also give you the chance to completely clean out your fluids and replace your Type F with today's better performing Dextron/Mercron 3. You do need to have the right torque converter for you application, depending on engine RPMs and Stall speeds. the correct selection will reduce the amount of "power Robbing" that you have herd of.
Old Sep 10, 2013 | 08:16 AM
jim collins
Bob
____Nope , don't believe you will have that problem like we can in a high desert area 6 months out of the year , but we don't have rust. __
Old Sep 10, 2013 | 08:56 AM
Corkwheats's Avatar
Corkwheats
Good Stuff! That makes a lot of sense. I bookmarked that site. Thanks.
Old Sep 10, 2013 | 12:17 PM
abyars111's Avatar
abyars111
Like others have mentioned if it's in good condition and you keep it cool and keep the fluid clean it will last a long time.
Mine is being gone through this week. The PATC site is a good one. I bought parts from Broader Performance. Broader Performance
I bought a wide power band to improve the holding power, new valve body with a shift kit for worktruck/towing. Someone had installed a shift kit in my valve body and I don't now how it's setup so I opted to just start over. I also installed a low stall RV/Towing torque converter from PTC Performance Torque Converters - Performance Torque Converters
The transmission shop is installing Raybestes best clutches and all new parts for everything else.
One reason that the C6 eats horsepower is due to the thrust washers used internally instead of roller bearings. You can google "roller C6" and find more info than you want. I bought a kit from Broader that swaps in roller bearings for the forward hub, rear planatary and #9 thrust washer. Probably overkill but I thought it a good idea while it's apart. I tow a camper with my truck so I wanted the tranny to be as efficient as possible.
Old Sep 10, 2013 | 01:27 PM
Corkwheats's Avatar
Corkwheats
Thanks again. This is especially good to know since mine will be a work/pulling truck here on the farm. Maybe not this winter - but next winter I'll upgrade the Transmission along these lines. I book marked all these sites under my C-6 Tranny Folder. I'm learning lots today - always a good thing!
Bob
Old Sep 10, 2013 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6: 13 quart capacity including the converter / 1966/76: Type F / 1977/97: Mercon aka Dextron II.
Replacing front pump seal: There are actually two (7A248). The front pump gasket (7A136) also has to be replaced.
