M5od Clutch
Old Jun 16, 2003 | 11:31 PM
adogg1us's Avatar
adogg1us
Angry M5od Clutch
I INSTALLED A NEW TRANS IN MY 93 EXPLORER I ALSO REPLACED THE CLUTCH, SLAVE CYL, AND MASTER CYL. AND NOW THE CLUTCH WILL NOT DISENGAGE. I HAVE BLEED THE SYSTEM AS PER THE SERVICE MANUAL BUT STILL HAVE THE SAME PROBLEM. AM I MISSING SOME THING? THIS SHOULD NOT BE DIFFICULT! ANY SUGGESTIONS
Old Jun 18, 2003 | 11:13 AM
mr clutch's Avatar
mr clutch
M5od Clutch
you could have a problem with the new clutch. What brand did you buy. Also the hydraulics on these can be a bear. You may have to bleed the system multiple times before you have all the air out. Alot of shops use power bleeders on the newer vehicles with the internal slaves. The power bleeder is used under pressure (20psi I believe) which helps considerably.
