Again,what do I own ??
Old Sep 4, 2013 | 05:16 PM
SaltySenior's Avatar
SaltySenior
asked this on 12/23/'11 and i'm still puzzled.... every thing says E-150..went shopping for tires and people seem puzzled with what they see as far as suspension,, lug pattern and tire requirements ( 10 ply ), they say everything looks like a E-250 or bigger...the GVW states 8600....is this some sort of a towing package offered by the factory ?? It is a 2008 ...........(.E -199)maybe ???
Old Sep 4, 2013 | 05:57 PM
Club Wagon's Avatar
Club Wagon
For 2008 E-Series (along w/new nose & dash) got "All-New Brake Systems" & the E150 brakes got unified/upgraded to the 8 lug E250 type.
Old Sep 4, 2013 | 06:45 PM
SaltySenior
that explains the lug configuration....but why the recommendation for such heavy duty tires.......i owned 2 other e-150 and they took plain old car tires.
Old Sep 4, 2013 | 07:35 PM
Club Wagon's Avatar
Club Wagon
Sure, people put "plain old car tires" on them, but since '92 that was not following FORD recommendations, which specifies XL tires.
Not sure '08 "tire requirements" call for "10 ply" on E150. Thought E250 called for 6 ply.
Old Sep 5, 2013 | 07:01 AM
JWA's Avatar
JWA
The year of your E150 should tell any competent tire dealer what minimum rating tire your chassis needs. If you're not exceeding its GVWR then a 6-ply LT tire should be more than enough for normal use. I myself use Michelins LTX (load rated E) on several E250's, same 8600# max GVWR, running as a daily driver @7800#
Yes once upon a time we didn't give much consideration to tire types but hopefully we've moved past that age of darkness and run what's safe not just what fits or is cheapest.
HTH
Old Sep 5, 2013 | 11:14 AM
Club Wagon's Avatar
Club Wagon
Once upon a time, Sam's Club had the best tire prices, even beat the big mail order tire sellers.
Then they stopped having the best prices & merely had the advantages of being close, quick & offered open tire racks, where you could handle & compare a decent variety of tires at your leisure.
Then they adopted a policy that dictated only the vehicle manufacturer's specified size tire would be installed in their shop. If you wanted oversize tires, you'd need to jack your vehicle up at home, take wheels off & bring to Sam for tire mounting.
Was told it was about liability. Tire dealers apparently can be sued if they install tires that don't meet "minimum rating" & there's a tire related accident. This would include mounting standard P rated tires on '92 & up E150.
Old Sep 5, 2013 | 11:50 AM
tabijan's Avatar
tabijan
Isn't there a tag on the driver door or doorjamb that specifies tire size, rating and pressure?
Sixto
93 E150 Chateau 5.8 186K miles XL tires
Old Sep 5, 2013 | 09:56 PM
Vanaddiction's Avatar
Vanaddiction
I believe the 8 lug E150's replaced the 5 lug in '07. I also have an '08 E150. I like the fact it resembles an E250 chassis in a passenger config. And please correct me if I'm wrong, but aren't vehicles over 8500 gvw exempt from CAFE standards? I know they no longer report MPG stats on the window sticker.
Old Sep 6, 2013 | 11:16 AM
YoGeorge's Avatar
YoGeorge
Yup, the '08 and newer 150's are really 250 "lites". I believe Ford did this because the 5-lug E150's, when converted with raised roofs and fancy seating etc., ended up with a payload under 1000 lbs, and got overloaded chronically and regularly.
They needed more brakes, etc, and adding this kind of weight would have put them out of the P rated tires, so they ended up using the 150 label as a "low price point" leader. And the 8600 lb GVW got them out of the CAFE mileage standards.
The harder ride, etc, make them less successful as "car like" van conversions, but that market has almost disappeared anyway.
George
Old Sep 7, 2013 | 02:49 PM
SaltySenior
George
your explanation makes sense and answers my question....
and the gas mileage i get proves it.
hmilycar
General Automotive Discussion
Jun 19, 2015 11:07 AM
fatheadon1
6.7L Power Stroke Diesel
137
Feb 1, 2012 11:36 PM
calshamus
56
Jul 8, 2011 09:41 AM
Grant N.
Oct 18, 2009 09:13 PM
ranch67
Aug 27, 2007 03:36 PM
