Headlights on 97 Explorer
Old Aug 26, 2003 | 07:23 PM
brif4i's Avatar
brif4i
Found it now I just need to find one in stock to replace it.
Old Aug 30, 2003 | 01:48 AM
mjrogers's Avatar
mjrogers
I had the same problem, except both of my low beam headlights wouldn't work. However, the high beams would.
I replaced the multi-function switch (turn signal, wiper, high beam) on the left side of the steering column and WALA the problem was solved.
It only took 45 minutes (most of which was spent trying to get the darn thing unplugged) and only cost $62.
Hope this helps.
Old Nov 19, 2018 | 11:13 AM
wmclark43's Avatar
wmclark43
My 97 Explorer has developed the rt side low bean not working but the left side is ok and the high beams are also ok.
Where is the Lamp Out Module located?
Thanks
Bill C
Old Nov 21, 2018 | 06:48 AM
shorod's Avatar
shorod
If your 1997 has the Lamp Out Warning feature, the module is located behind the instrument panel console, kind of to the right of the accelerator. It will have a gray connector that's wide and flat, 10 terminal locations on the bottom row and 6 terminal locations on the row with the the connector retainer. Only 13 of the 16 terminal locations are populated.
-Rod
Old Nov 21, 2018 | 10:56 AM
wmclark43's Avatar
wmclark43
Location of the module
Hi Rod
Since I posted the question I have looked on YouTube and the videos there show it in the console under the information panel on the right side. I found a picture of it online and your pin description is spot on.
Interesting but I also found a wiring diagram that show either with or without the lamp out module
Do you know of a way to skirt around the rt side low beam?
The diagram shows pin 1 and 11 for the rt head light and a test is to unplug the module and jump 1 to 11 and the rt side will come on with the head light switch turned on - of course all the rest of the lamps and bulbs that are associated with the module will be off.
Just a thought
Bill
Old Nov 23, 2018 | 07:09 AM
shorod's Avatar
shorod
Yep, to bypass it looks like you would jumper pin 1 to pin 11 (left hand headlamp), pin 12 to pin 13 (right hand headlamp), pin 5 to pin 6 (rear park lamps), and pin 14 to pin 15 (rear brake lamps).
The remaining 5 wires are power (pin 7), ground (pin 9), and the three "lamp out" warnings (pin 2 for headlamps, pin 3 for rear parking lamps, and pin 4 for brake lamp). It's unclear if the lamp out signals are normally floating or if the display is expecting power, logic level, or ground in a situation where the bulbs are working. So making the jumpers listed in the first paragraph should keep the lights working, but keeping the display happy may require further investigation.
Depending on your mechanical and soldering skills, you may be able to open up the lamp out module, find a bad solder joint or bad component, replace it, and have a working system again. If you opt to just bypass and remove the module and would otherwise plan to just throw it away, I'd be interested in taking a look at it to see if it's a simple repair if you'd be willing to go to the trouble of shipping it to me. I haven't had the opportunity to take one apart to see if I can determine the failure mode.
-Rod
Old Nov 23, 2018 | 11:21 AM
wmclark43's Avatar
wmclark43
Jumper
Rod-
Looks like I'll try the repair first and if that fails i'll go for one jumper only as in my case it is the low beam on the rt side
Thanks for the reply. This repair will have to wait until the wind and snow calms down. I am headed with camp trailer to warmer parts
The Explorer is a local runner and can wait
Sad story with this Explorer, over the years we have hit 3 deer that I know of. The front grill and head lamp and turn signal plastic/steel parts are held together with silicone , glue , plastic ties so the head lamps don't really function the best.
The head lamp alignment moves around a bit.
BC
Old Nov 23, 2018 | 11:24 AM
wmclark43's Avatar
wmclark43
Rod-
Forgot to add that yes if I do take the relay out I'll ship it to you.
There will come a time when duct tape and bailing wire will fail me and the whole Explorer will go.
BC
Old Nov 5, 2019 | 01:19 PM
Robert Jeffcoat's Avatar
Robert Jeffcoat
same problem I have no power on fuse #4 , #8 and #33 HELP
Old Nov 5, 2019 | 08:46 PM
shorod's Avatar
shorod
Welcome to the forum. There have been a few different scenarios presented in this thread, so I'm not sure which one your symptoms match. is your Explorer also a 1997? Does it have the Lamp Out module?
-Rod
Old Nov 5, 2019 | 09:02 PM
Robert Jeffcoat
-Rod
97 explorer eddie bauer no head lights, power to switch is good no power to mfs . no power to lom on #1 do have power on #5 marker lights work just fine and go off automatic.
power goes to switch-mfw-to fuse #4 #8 and #33 no power at any of the three fuses????????????????????
dadlovesfords
1997 - 2003 F150
Dec 2, 2014 03:02 PM
bellpr
Oct 27, 2009 02:01 PM
metauser
19
Mar 12, 2006 01:57 AM
MattamiscontisME
Dec 24, 2005 06:47 PM
Soulseeka
Jul 16, 2003 09:54 PM
