Transfer case output shaft
Old Jun 16, 2003 | 10:01 PM
Mikes95's Avatar
Mikes95
95 Bronco XLT, 127k with BW 1356 TC
Should there be any movement in the rear output shaft? I had the drive shaft out and was poking around and noticed if you grab the companion flange on the TC output shaft it will move in and out a little. I’m wondering if this is the cause of the clunk when I engage reverse. There is no slop on the diff flange. Whatya think?
Old Jun 17, 2003 | 11:21 AM
z 97ford1's Avatar
z 97ford1
Output shaft moving in or out I don't think would be a problem.....side to side I think would be.
If your getting a "clunk" then simple lube the male and female splines and any seal with ford "teflon" grease and I bet your "clunk" will go away.....mine did.
