I've updated, upgraded, and improved the tech folder and I'm now cross-eyed from all the coding I've struggled with.
Anyway, I've added most of the threads I've been collecting and putting on the back burner until I finished this project, but I know there has to be more possible "How To" threads I might have missed. I need the collective to post up here with links to threads I missed (don't bother checking to make sure I got all of Christina's threads...I did) so I can see if it warrants inclusion in the folder.
Thanks y'all!
Stewart
Thanks Stewart, will have to go check out your new setup. I'm flattered.
Just added Mark K's trans fluid changing procedure, how to grease your slip joint, FMC technical resource link, and a DIY tow-hook work platform instructional.
Well done Stewart, awesome job! I didn't see any of SpringerPop's mods. Could be a few helpful ones there. SpringerPop's F-350
Last night I pulled up Woodnthings help page and linked to the applicable info, but when I clicked on the link I had saved for Marv's page, I had an old, bad link. It was late so I didn't bother searching for a post by Marv so I could access his sig and update my saved link. I figured I would do that tonight. Thanks for the heads up tho!
