No Limit rack
Old Sep 2, 2013 | 09:20 AM
exidenick's Avatar
exidenick
No Limit rack
I'm at the point that I need to start to plumb my no limit rack. I know a lot of guys have done this conversion with success. I need to know what power steering pump to use. No Limit does not give any recommendations so i'm in the dark. Any help is appreciated!
Old Sep 2, 2013 | 06:05 PM
spurredon's Avatar
spurredon
Probably if you search "power steering", here on the forum you will find what you want and more.
Old Sep 2, 2013 | 10:36 PM
2losteve's Avatar
2losteve
What engine are you running?
Old Sep 3, 2013 | 07:02 PM
exidenick's Avatar
exidenick
I'm running a 351C. There are a lot of threads on the rack but no one mentions what pump to use
Old Sep 3, 2013 | 09:30 PM
2losteve's Avatar
2losteve
I would be inclined to run the Ford pump that bolts to your Cleveland. I've got a Ford pump powering a Camaro box and a Chev pump on a Ford rack. They both work fine. Did No Limit tell you what type of rack it is?
Steve
Old Sep 4, 2013 | 01:00 PM
vntgtrk's Avatar
vntgtrk
I'm not sure, but I don't think it matters what pump you use as long as it fits the engine and you have no leaks
Old Sep 4, 2013 | 07:47 PM
klr's Avatar
klr
pump
i believe the rack is similar to the later model thunderbird, the information should be in the paper work you got with the front end
Old Sep 4, 2013 | 08:55 PM
vntgtrk's Avatar
vntgtrk
POWER STEERING STRAIGHT AXLE-No Limit Engineering-
Is this the one you're using?
Old Sep 5, 2013 | 12:49 AM
Koolkat's Avatar
Koolkat
It says on the last page of the instructions that any pump is OK to use.
Old Sep 5, 2013 | 09:35 AM
vntgtrk's Avatar
vntgtrk
Let us know how this goes installation wise and how well it works. I'm using stock axle myself
Old Sep 6, 2013 | 09:13 AM
exidenick's Avatar
exidenick
I decided to go with a new ford pump that I got for cheap since it is a ford rack and I fabricated brackets. I should have it up and going this weekend I'll post how it turned out and post some pics in my gallery on the completed project. Thanks for everyone's help.
Old Nov 13, 2013 | 01:21 PM
exidenick's Avatar
exidenick
Well I finally got everything finished. Had brackets fabbed up and its plumbed. It works great, no more hard steering when i'm trying to move it. On to the next steps. I added some pics in my gallery
Old Nov 13, 2013 | 09:13 PM
2losteve's Avatar
2losteve
Congrats on a job well done. Thanks for the update too.
Steve
Old Nov 13, 2013 | 10:15 PM
vntgtrk's Avatar
vntgtrk
Good looking install. Any oil pan clearance issues?
Old Nov 14, 2013 | 02:20 PM
theodore/teddy's Avatar
theodore/teddy
Refyred
Does the electric motor run the water pump? Looks like you have a pusher radiator fan.
