2005 f350 overheating
Old Aug 31, 2013 | 10:36 PM
ItsMREMT's Avatar
ItsMREMT
Question 2005 f350 overheating
I have a 2005 f350 that is overheating. Under a load I seem to have coolant, leaking down my front driver side spring. I do not hear my clutch fan kicking in but I dont believe that would cause the coolant leak. I am thinking I blew a head gasket.
has anyone used this method to test if there head gasket is blown?
Old Aug 31, 2013 | 10:37 PM
ItsMREMT's Avatar
ItsMREMT
figured out how to post the url
Old Aug 31, 2013 | 11:13 PM
04badford's Avatar
04badford
That's the most effective way, But, I would watch diesel tech Ron video he's a lot better. ( Ford Tech).
Old Aug 31, 2013 | 11:34 PM
BLADE35's Avatar
BLADE35
X-2^^^^^^^Theres Lots better vids out there then Bill
Not Common to Have a External HeadGasket Leak
In that Area Id say its Likley a Cracked Tank Seam or Hose or Venting out the Cap
Is your coolant bottle got white residue on top around the cap??From PUKING
Old Aug 31, 2013 | 11:53 PM
04badford's Avatar
04badford
I'm thinking a good flush is in Order and get an OEM Thermostat, when was the last degus bottle cap change.
Old Sep 1, 2013 | 12:08 AM
99ExpyProblems's Avatar
99ExpyProblems
Near the spring, I believe there is a Y fitting under the degas bottle that could be cracked and leaking.
Old Sep 1, 2013 | 10:51 AM
cheezit's Avatar
cheezit
6.0 heads dont leak externaly, or not that i have ever seen or heard of
Old Sep 2, 2013 | 11:31 AM
ItsMREMT's Avatar
ItsMREMT
Thanks everyone for your replies... I will flush my coolant and change my coolant filter today. My cap I have not replaced it. I will also do a pressure test today, I hope I don't have a head gasket issue.
Old.Faithful
24
May 29, 2016 11:31 PM
Jugger
Jan 5, 2012 04:00 PM
tony. b
Aug 1, 2011 10:01 AM
TonyPark33
Jan 31, 2011 12:07 AM
