Electric window problems
Old Jun 16, 2003 | 06:06 PM
AlasKen's Avatar
AlasKen
94 Explorer. Passenger electric window will go down but not up. Tried both drivers side and passenger side switches. There is no sounds or voltage drop when trying to roll up. Still goes down. Is there a selenoid that may have stuck. Any ideas on troubleshooting? I hate to replace the motor if there are other options. Is this a common problem? Thanks in advance for any help you might have.
AlasKen
Old Jun 19, 2003 | 09:56 AM
steve83's Avatar
steve83
If the motor works going down, then it's OK. Your problem sounds like the switch.
Old Jun 19, 2003 | 11:18 PM
rickoh's Avatar
rickoh
I found the window switch on the drivers door is prone to having the wires break off the connector on the switch. Had the same problem and found a wire broken off the switch...
