86 2.9 Gets too rich?
Old 08-31-2013, 08:50 AM
1951D47U's Avatar
1951D47U
1951D47U is offline
I have a 86 2.9 Ranger 5 sp that starts great , runs good until warm, and then seems to get too rich at idle and may die, although not always. Still seems to run good down the road although the mileage has gone down. Each time you come to a stop though it will most likely act like it is getting too rich and idle terribly, possibly dying if you don't goose it once in awhile. Have replaced plugs & wires, MAP, blocked off EGR, and can't get any codes too show. Any ideas?
Old 08-31-2013, 02:45 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Check the fuel pressure. At the top of the engine you'll find what looks like a tire valve. Screw on the gauge turn the key on/engine off & see what you get. It should hold steady at about 40 PSI.
Don't have a gauge? The last one that I bought from Harbor Freight was about 17 bucks. You want the one for fuel injection.
Old 09-01-2013, 01:49 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I have a rich condition too curious what you find
mine might be an 02 sensor
dropper
4 Cylinder Engines
01-14-2011 01:35 PM
KrAzYKARL
4 Cylinder Engines
13
10-08-2006 11:16 PM
Bruce Maurer
10-13-2005 03:13 PM
tmolandes
Bronco II
11-10-2003 02:15 PM
mrblue01
03-05-2003 03:08 PM
Quick Reply: 86 2.9 Gets too rich?
