NY's is it really September 2013 BS thread
Sep 18, 2013 | 07:52 PM
Least days isn't messing with you.
Sep 18, 2013 | 08:19 PM
Still all sorts of stuff going on Rick.
Sep 18, 2013 | 08:29 PM
Good evening Neil, Rick, Shaun, Steve and everyone
Hope you had a great day
Sep 18, 2013 | 08:56 PM
so every now and again my truck will stop drawing fuel. crank the motor and sit for 30 seconds and it draws again... any ideas?
Sep 18, 2013 | 09:00 PM
Quote:
Originally Posted by
infinite-foamies
Might need a fuel pump... Could have a hole inside that let's the line drain back..
And you need to refill the line to start it
My 2 cents guess
Sep 18, 2013 | 09:01 PM
Would be a good guess Don.
Sep 18, 2013 | 09:19 PM
changed the lift pump last year(the only one) and it actually happened while driving once
Sep 18, 2013 | 09:22 PM
infinite-foamies
Try replacing the fuel line between the pump and carb..
Maybe there is a small crack or it is collapsing and not allowing enough fuel through
Also make sure all clamps are tight on fuel lines
Sep 18, 2013 | 09:25 PM
What year and what motor Eric?
Sep 18, 2013 | 09:26 PM
fire240
Good question..
I assumed the 88 f359
Sep 18, 2013 | 09:36 PM
yes 88 f350, 7.3 idi so no carb
Sep 18, 2013 | 09:42 PM
infinite-foamies
That will make a difference then...
Again I assumed it was gas... Didn't look at your sig..Lol
Sep 18, 2013 | 10:07 PM
Could be pulling in air from the fuel return lines. It runs between the injectors. Pretty much just fuel grade rubber hose. Had that issue on the old ambo we had. Had to replace the rubber fuel lines between injectors and the orings.
Sep 18, 2013 | 10:26 PM
Well I am gonna call it a night guys..TTYL
Sep 18, 2013 | 10:48 PM
