Battery ??
Old Aug 30, 2013 | 04:48 AM
mike L's Avatar
mike L
Battery ??
Would not start for two days, had to jump start. Nothing was left on like the lights, glove comp. light ect. Had a Charging System Test done at Advance. Print out says the starter tested ok, charging system ok, but a charge is required. It had 12.65 volts during test. It says because of low charge check my connections??? When I got home I turn the engine off twice. It would not start the second time the battery read 8 volts.
So do I need to try another battery I have, to see what's up. Or could I damage it?
Old Aug 30, 2013 | 05:35 AM
bashby's Avatar
bashby
Sounds like a bad battery to me.
Old Aug 30, 2013 | 07:57 AM
hotrod351's Avatar
hotrod351
autozone should be able to test it and tell you if the battery has a dead cell.
Old Aug 30, 2013 | 10:15 AM
mike L's Avatar
mike L
I had it tested, result above. Would I have to remove the battery and have it charged overnite there? How can I tell if its the battery and not a wiring problem?
thanks
UPDATE: Manager just said the print out I got was a false +, It was a bad battery.
onug
2015 - 2020 F150
Dec 28, 2018 08:27 AM
79F-1504x4
53
Mar 3, 2011 01:53 PM
gweeds
Mar 30, 2008 08:40 AM
mike L
Oct 21, 2005 09:36 PM
kochy54
15
Apr 21, 2002 05:31 PM
