97 Expy Performance
Old Jun 15, 2003 | 11:00 PM
bewkst's Avatar
bewkst
97 Expy Performance
Does anybody know what Ford did in 99 to go from 235 HP to 260 on the 5.4L? Does anybody know whether the transfere case was changed that same year as well?
Thanks
Old Jun 16, 2003 | 05:29 PM
the4by4freek's Avatar
the4by4freek
97 Expy Performance
Transfer case was changed, they removed the 2HI function from it. It turned into a A4WD system only.
I think thet they changed the heads on the 99 to bump the horsepower. Hope this helps!
Old Jun 17, 2003 | 10:36 AM
Rtpjunior's Avatar
Rtpjunior
97 Expy Performance
I'm not sure if this is the only change, but they switched to a different intake manifold in 99. The new one is made of a composite material, I believe, and of course, it will not retrofit onto the older motor. The ports will misalign.
Old Jun 17, 2003 | 11:57 AM
BigMattXXL's Avatar
BigMattXXL
97 Expy Performance
Yeah - they put the "PI" heads on the motors. If you check through the passenger side front wheelwell, you can see a number stamped on the head. Look for "PI". This means you've got the more powerful motor.
XXL
