Turning Issue
Old Aug 29, 2013 | 06:36 PM
wallace32's Avatar
wallace32
Turning Issue
I wanted to ask if anyone else has had problems with steering issues with their trucks. When I am turning hard over either way, I feel like the tires are hitting the leaf springs. kinda like a grind/bounce feel in the steering wheel. The tires are 285/75/16, so only wider than stock tire size. I turned the wheel all the way over one way and got down from the truck to feel if the tires were hitting the leaf springs, but they don't seem to be. Might this be a large problem? It just started today. Thinking of getting it looked at, but the shop I'd like to take it to is closed until Tuesday next week. Any ideas before I go to a shop? Thanks guys.
Old Aug 29, 2013 | 06:42 PM
69cj's Avatar
69cj
Would be nice if we knew what you're driving and any suspension mods!
Old Aug 30, 2013 | 07:21 AM
wallace32's Avatar
wallace32
I guess I was tired yesterday. It's an 06 F350 crew, 4x4, srw. I bought the truck used and so as far as I know, no suspension mods. I'm going to pop the hood to check power steering fluid level and get under her to check for any leaks or if anything is loose. I had the ball joints replaced within the last couple of years and they shouldn't need to be replaced. Thanks for any help.
Old Aug 30, 2013 | 09:14 AM
rhjj's Avatar
rhjj
Axle u joint?
Old Aug 30, 2013 | 10:02 AM
davlan88's Avatar
davlan88
I have this same issue on a hard left turn on a stock 04 F250 CC SB SRW. I was thinking hub seize or axle joint. I have to replace my steering links first though to eliminate that as they are obviously bad. I'm curious how to troubleshoot the axle joint as well.
Old Aug 30, 2013 | 11:20 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
This concern wore me out until I realized my exhaust downpipe was tweaking and touching (the vibration made it feel like a rubbing or grinding)...almost like a bad Wheel hub assembly. Check this...easy fix if that's what it it.
Old Aug 30, 2013 | 11:23 AM
99ExpyProblems's Avatar
99ExpyProblems
I have the same issue on a slight left turn, not hard. It only happens when on a winding road. There is a groaning noise. I can't find it either.
Hmmm, I'll have to check this. That's what mine sounds like a groaning/grinding.
Old Aug 30, 2013 | 11:44 AM
MoyockPowerstroke
Yep...it only occured on mine after I added the 4" DP and while making left turns.
Old Aug 30, 2013 | 01:41 PM
diesel_dan's Avatar
diesel_dan
And you can forget the rubbing leaf springs as your '06 4x4 has a coil front suspension....
Old Aug 30, 2013 | 01:44 PM
diesel_dan's Avatar
diesel_dan
You sure it's an '06? I just realized 16s don't fit on '05 and up -- minimum is a 17....
Old Aug 31, 2013 | 07:37 AM
wallace32's Avatar
wallace32
I got new brakes yesterday and will try driving the truck today, wife wanted to drive the truck home after the brakes were installed. I just want to see how it feels after this fix. I'm hoping it wouldn't be anything major. When I had the ball joints replaced a couple of years ago I was told that everything else looked fine in terms of steering the suspension components. With the issue I'm having, it would be noticeable only in the winter. I thought it was snow or ice build up in the wheel well, but now that it's happening when there isn't any snow, It's my guess it is a warning sign that something might be needing some attention. I was going to be buying tires this fall and I figured I would go back to stock size tires to see if this might help. My thinking is that it could be hubs or steering box. I was told in the past that with larger than stock tires the steering components would wear more quickly due to additional weight of the larger tires. That was factor in my decision to go back down to the stock tire width. I am hoping I have time next week to have it looked at when the shop opens back up. I will let you all know what I find as I move through the process of elimination.
Old Oct 2, 2013 | 10:10 AM
wallace32's Avatar
wallace32
Ok, got an update. I had to take the truck to a shop twice for them to find the problem. I was told that my 4x4 transfer case had 4 high engaged and that was causing the noise when turning. They let me know that I need the transfer case solenoid motor replaced. In case anyone else has this problem I had the following symptoms: noise from front end when making turns both right and left-this was when turning hard over, decrease in fuel mileage, bump/rubbing feel in steering wheel when turning. I let the shop owner know that when I was researching this online that I came across a number of recommended issues that would cause this, but none related to the transfer case. Just called the local dealership to get a quote on the solenoid, $565. Might anyone know if this is just an unplug and unbolt part that can easily be replaced or is it a part that requires removing the transfer case, checking this, that and the other?
Old Oct 2, 2013 | 12:25 PM
big inch's Avatar
big inch
The transfer case being stuck in 4 high shouldn't affect the steering unless the front hubs are also locked in. Have you checked the front hubs to see if they are in auto or locked?
The transfer case shift motor is bolted onto the driver's side of the case. It is not difficult to replace, if that is what it needs.
Old Oct 2, 2013 | 12:44 PM
JBSIXGUNS's Avatar
JBSIXGUNS
You shouldn't need to remove your transfer case, to replace the shift motor. If it were me, I would drop the transfer case skid plate ( 4 bolts ) and the front drive shaft ( 8 bolts ) to make plenty of room to remove the transfer case shift motor. It has a 3 pin connector on the bottom side, and a 6 pin connector on the top side. Both plug in horizontaly. Be careful not to break either of the ears off on the harness connectors when you unplug them. Then you should be able to unbolt the transfer case shift motor (4 bolts) and bolt the new one in. Plug the wiring harness connectors back in, start the truck and ingage the 4 wheel drive, to make sure the issue is resolved before bolting the front drive shaft and skid plate back in.
Here is a link for the part you need, allot cheaper than ford, with lifetime warranty...
http://Www.1aauto.com/1a/transfercas...15/432142/2006
Old Oct 2, 2013 | 05:44 PM
wallace32's Avatar
wallace32
Big Inch, I think the hubs were trying to lock or partially locked and that was causing the noise and feel. Also made the truck run more inefficiently - noticed the mileage per gallon decrease due to it being in 4 high. Thanks for all the input fellas. Now time to find the time to get under there and try to fix. Thanks. I will update when it is fixed.
