Sponsored by: Real Truck
Need help with 4wd engaging
Old Aug 28, 2013 | 12:02 PM
carbon101585's Avatar
carbon101585
Hey guys, I'm a new member and I want to take a moment to thank all of the enthusiast on here for your knowledge and input.
I have a 2002 7.3l f350. I took it in to check the 4wd and my mechanic told me I needed both front hubs, ball joints and all the seals within the hubs. I just picked up truck and when I use esof only the passenger side auto locks and air goes into the defrost windshield. I know the pump is working because it locks/unlocks passenger side. But what's wrong with drivers side?
When I tried checking vac lines on drivers hub, one was not connected. After I connected it, same issue.
Any advice?
Old Aug 28, 2013 | 12:37 PM
2000silverbullet's Avatar
2000silverbullet
4wd and defrost is indicative of a vacuum leak. Check your lines to the drivers side hub.
Welcome to FTE.
Old Aug 28, 2013 | 12:43 PM
carbon101585
Thank you, I was reading that. However, I was also reading that with hubs on "auto" and inside truck you select 4wd lo...only one front wheel really locks..? The only way to lock both front is to manually do it..?
Am i in left field with that info?
Old Aug 28, 2013 | 03:29 PM
senix's Avatar
senix
Front driveshaft is an open differential type unit. So until you find the vacumn leak just turn the hubs to lock.
then use the switch and it will engage the transfer case so you have 4wd. Repair the leak and probably need to grease the hubs.
Old Aug 28, 2013 | 04:56 PM
carbon101585
With a vacuum I tested the hubs with the vacuum tester and both are sealed and hold vacuum, and now my questions
the driver's side hub won't unlock after vacuum testing..?
Abs light came on (mechanic changed hubs, ball joints and seals), did he do something wrong?
Should I replace the short hoses in back of the wheels and see if vacuum holds since the hubs are holding vac?
Thank you
Old Aug 28, 2013 | 05:03 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, you're in left field. If working properly, both hubs should lock in 4H or 4L.
Old Aug 28, 2013 | 05:12 PM
2000silverbullet
Lock on the hubs is just an override should the "auto" fail.
Old Aug 28, 2013 | 06:52 PM
carbon101585
Thanks guys
Old Aug 28, 2013 | 08:12 PM
redford's Avatar
redford
Thanks guys
Based on what you're telling us, yes he did.
Old Aug 28, 2013 | 08:16 PM
senix's Avatar
senix
sounds like a tear down of the suspect hub is in order to me too.
Old Aug 30, 2013 | 12:06 PM
carbon101585
Update: Mechanic changed solenoid for vacuum 4wd system and put back my old abs sensor (new one was faulty). Everything seems to be perfect now, thank all of you for your input, hopefully this thread serves as another guidance to someone else.
Old Aug 31, 2013 | 09:40 AM
nitrogen's Avatar
nitrogen
as far as one front wheel locking in 4lo, yes and no. both hubs DO engage, but since it is still an open diff only 1 will spin. both will still produce torque
cuttn4fun
Nov 21, 2012 12:01 PM
mrdoughnut
Feb 26, 2012 01:20 AM
AndeyHall
Jun 1, 2011 01:47 PM
terry_opie
Modular V10 (6.8l)
Jan 9, 2011 01:31 PM
dbmstr124
Mar 11, 2008 09:56 PM
