brake upgrade questions
1. According to the tech article the f350's master cylinder is to wide to fit on my booster right? So I was going to get a f350 booster but someone told me that the mounting bracket is different. Is this correct. Can I still use it even though it is different?
2. I am changing my rear brakes over to disc by using TSM Mfg's kit. My question is with the f350 master cylinder will it work correctly with the monte carlo calipers? They have a 2 13/32 piston diameter.
Thanks guys
Richard
You could remove your booster and compare the mounting to an F350 booster.
My F350 booster has 4 mounting studs on a 3.5" high by 3.75" wide pattern.
I don't know about the piston dia.
