Hey my truck stumbles really bad from about 600rpm to about 1000rpm only after it is warmed up and only starting from a stop. After 1000rpm it picks up and accelerates fine. My truck is an 86 F250 with a 460 4spd, new edelbrock carb, stock ignition with new cap, rotor, plugs, wires. If anyone has any ideas I would appreciate it very much. I have been playing with the carb but could this be an ignition problem? Maybe I am barking up the wrong tree. Thanks again for any help.
Ryan
Do you have stock ignition? Check accelerator valve. Check timing. Retard advance and try again???. Accelarator valve is my guess. I have 460 too and seen this done this. Either to much or to little gas on accelatoration.
I have a 83 E350 4x4 with a 460, 4.10 gears, C6, NP205 transfer case. I installed an Edelbrock 1411 (750cfm with electric choke). The engine was completely stock and I experienced the same stumbling problem from idle up through about 1200 rpm or during a 1000 -1400 cruise level. I had to continue changing the metering rods and jets as listed in the manual to a richer condition until the stumbling went away. I ended up with 0.113 jets and 0.63x 0.37 rods. I installed an MSD6a ignition and MSD wires and cap, along with an open K&N Air filter and have advanced the initial timing to 16 degrees with no pinging. The van only stumbles slightly after sitting hot for a while and this goes away shortly (heat related). The plugs look good and the van has good power, tows my 3000lb boat well and acceptable milage(9.4). Good luck
