HOT FEET!!
Old Aug 24, 2013 | 10:18 PM
Splatts's Avatar
Splatts
HOT FEET!!
I am sure I'm not the only one but I get a ton of really HOT air coming from the vent under the center of the dash with the heater turned off. When I switch to defrost it goes away. Is there anyway to stop this? Other than having the defroster on all the time. I have the climate controls set to all the way cold and off. It feels like a hair dryer on the hottest setting blowing on my feet, it's fricking HOT!!
On a "cooler" note I'm getting an A/C installed next week. Found a factory kit online that includes all factory components and controls. I would install myself but no place to do it family summer road trips in the truck coming soon
Old Aug 25, 2013 | 01:03 AM
stainlessstroker95's Avatar
stainlessstroker95
You may try the cold a/c mod. Which is really just a valve that shuts off water flow through your heater core.
Old Aug 25, 2013 | 06:58 AM
fordman67's Avatar
fordman67
That will help..no ac truck?wwow.don't see that much here.
you can do a vaccum operated one or a mechanical and get a generic choke cable and use that to operate it. install in rhe hose coming from the head iircc.
Old Aug 25, 2013 | 07:19 AM
oldbird1965's Avatar
oldbird1965
x3 on the ac mod, love mine.
Old Aug 25, 2013 | 07:27 AM
fordman67's Avatar
fordman67
I need to do it on mine ..i have been distracted lately though
Old Aug 25, 2013 | 07:36 AM
oldbird1965
No excuses Aaron, 'get her done'. LOL
Old Aug 25, 2013 | 07:48 AM
fordman67's Avatar
fordman67
Been working on my 41 ford.got the whole butt cut out. front floor and tunnel fabbed and welded in.iill throw pics up in ot thread tonight for approval.lol
Old Aug 25, 2013 | 08:33 AM
ReBilld's Avatar
ReBilld
You go boy!!!
Old Aug 25, 2013 | 11:16 AM
Splatts's Avatar
Splatts
That's part of the reason I got the truck so cheap vinyl seats and rubber floors not a single luxery item in it. Lol. so basically the valve will stop the heater core from "working". Close the valve in the summer, open in the winter. Sounds easy enough.
Old Aug 25, 2013 | 11:19 AM
fordpride's Avatar
fordpride
Might want to check the blend door. Something might be in its way stopping it from closing all the way
Old Aug 25, 2013 | 12:56 PM
stainlessstroker95
Could have some blend door problems too. My brother had a pen that fell down the vent and prevented the door from fully closing.
Old Aug 25, 2013 | 07:12 PM
427 fordman's Avatar
427 fordman
The only thing I noticed better with my cold ac mod is that it stays cooler if its hot out and im in town traffic. Otherwise on the highway, it's pretty much the same.
Old Aug 25, 2013 | 07:45 PM
Splatts's Avatar
Splatts
When the heater/a/c is turned off, the door to the vent that goes to your feet should be closed correct? Because mine feels wide open and on max heat.
Old Aug 26, 2013 | 08:15 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
my 'new truck' has a similar issue of 'always on heat.' I just roll down the windows for now and figure i'll get to fixing it later, but just this weekend I noticed that the white vacuum tube going to the actuator that is directly under the passenger side hood hinge has been chewed in half by mice. i'm guessing that is my problem (and maybe something similar for the OP), but not sure.
does anyone know:
1. is that actuator the 'blend door' actuator? I assume it is, as its just after the blower box, but I haven't consulted the manual yet.
2. does it default to 'floor heat' when it has no vacuum to it?
Old Aug 26, 2013 | 09:31 AM
farmert's Avatar
farmert
When a vaccume pump fails, the heater usually defaults to the defrost position. I know the white vaccume line you are talking about, but don't know where it runs to.
