Battery Problems
Old Aug 24, 2013 | 09:04 PM
YoungGunSpencer's Avatar
YoungGunSpencer
Battery Problems
I disconected both hook ups and cleaned them. I charged it and put it back in, and I fired her up and backed away from the garage and she dies... but fired right back up, but the cab lights brighten and dim. Will a new battery take care of this or is a bigger problem trying to show it self?
Old Aug 24, 2013 | 09:07 PM
ranger429's Avatar
ranger429
You might want to think about a new cable? With the way this one looks I could only imagine how bad the rest are.
Old Aug 24, 2013 | 09:11 PM
devino246's Avatar
devino246
Sounds more like you've got another problem. How's the truck idle? Poor idle would explain the cutting off and dim lights.
Old Aug 24, 2013 | 09:13 PM
YoungGunSpencer
I plan on redoing alot with this truck, what doesn't get me is that it ran fine a day ago
Old Aug 24, 2013 | 09:14 PM
YoungGunSpencer
its idle is decent not great but not bad
Old Aug 24, 2013 | 09:23 PM
devino246's Avatar
devino246
Did anything else change from a day ago? When do the lights brighten/dim? Did the truck only cut off the one time, or is it recurring? What prompted you to charge the battery and clean the connections?
Old Aug 24, 2013 | 09:38 PM
YoungGunSpencer
nothing else really changed/ they dimmed when I a put my foot on the break and shifted into reverse/ then it cut off and fired back up and seemed to be fine/ My dad told me I should clean the connection and on are battery charger you can check the battery and it read low and so I hooked it up to the charger
Old Aug 24, 2013 | 09:41 PM
Scifi266's Avatar
Scifi266
You can usually take your battery to a parts house and they can test them. I would check your cables though, after a few decades they can get very brittle and weak. How's the alternator on the truck? do you know whether or not it's charging the battery correctly?
Old Aug 24, 2013 | 09:43 PM
YoungGunSpencer
@scifi Thats where my search was headed next.
Old Aug 24, 2013 | 09:46 PM
devino246's Avatar
devino246
Did they dim as soon as you applied the brake, or when you shifted into reverse? Did they continue to stay dim after you shifted into reverse? I just don't see an alternator or battery issue resulting in spontaneous stalling, though. With a bad alternator or poor charging system connection, the battery should support the ignition system for a short time. A bad battery or battery connection would result in a no-crank or slow-crank symptom.
Old Aug 24, 2013 | 09:48 PM
YoungGunSpencer
@devino when i appiled the brake they went dim and never went back to as bright as they were and then dimmed off
Old Aug 24, 2013 | 09:52 PM
devino246's Avatar
devino246
@devino when i appiled the break the went dim and never went back to as bright as they were and then dimmed off
That's the result of your idle speed being pulled down by the transmission being put in gear. It's possible that you have a vacuum leak or a blocked idle circuit.
Old Aug 24, 2013 | 09:53 PM
YoungGunSpencer
they* brake**
Old Aug 24, 2013 | 09:55 PM
devino246's Avatar
devino246
they* brake**
Posts can be edited by clicking
Posts can be replied to by clicking
Old Aug 24, 2013 | 09:58 PM
YoungGunSpencer
thank you for the truck and forum help
