Pick-up died
Old Aug 24, 2013 | 12:11 AM
fancyvern's Avatar
fancyvern
Pick-up died
I have a 2006 5.4 F-150. The unit had a miss. The scanner said no. 5 cyl. was missing. switched fuel injector and coil with no. 6 and still had the miss on no. 5.. Installed new plug on no. 5 and still have the miss. I drove it about a half mile and it died. tried new fuel pump relay no help. You can hear the pump when you turn the key on . When you go to the start side and crank it, it tries to start for a second or two. I put a new fuel filter on and it did not help. there are no other codes. It is not being nice. Thanks
67camaro
1997 - 2003 F150
Apr 11, 2018 12:50 PM
Jon_C
Mar 11, 2017 06:51 PM
Dpr99
1997 - 2003 F150
Nov 26, 2013 04:52 PM
grader61
Jan 25, 2009 12:24 AM
