Sponsored by: Real Truck
axle cap removal
Old Jun 15, 2003 | 02:04 PM
WoodN1_76's Avatar
WoodN1_76
Angry axle cap removal
I am trying to do a brake job on a 2 1/2 ton rear. I'm trying to get the axle caps ( the 4inch cap that has all the bolts in it in the middle of the brake drum) off.
I have all the bolts off, but it refuses to come loose on either side.
Should I continue with penetrating oil and trying to pry a screwdriver between the cap and the drum? Or am I doing something wrong? Thanks for all your help!
Old Jun 15, 2003 | 02:49 PM
kehale's Avatar
kehale
axle cap removal
usually, you have to hit it with a hammer to knock it loose.
-T
Old Jun 15, 2003 | 04:59 PM
WoodN1_76's Avatar
WoodN1_76
axle cap removal
Thanks for the reply, kehale. In the past I have never had a problem with these. I have only done one or two, and they came off with a couple of taps, but this one is being difficult! I have a big hammer and both sides are not budging.
Has anyone else had problems like this?
Old Jun 15, 2003 | 05:07 PM
kehale's Avatar
kehale
axle cap removal
Does this particular one screw off?
Not sure.
TIP OF THE DAY: Remember, HEAT makes metal expand. COLD makes metal contract. (I use compressed NO2 to make things cold (for ease of assembly)
-T
Old Jun 15, 2003 | 05:58 PM
WoodN1_76's Avatar
WoodN1_76
axle cap removal
I can't see how they would screw off because of the studs going through the outer edge of the cap. If it screwed off, they wouldn't be there. (I think!)
Old Jun 15, 2003 | 06:02 PM
kehale's Avatar
kehale
axle cap removal
Sometimes the end caps are bolted through the axle shaft (not housing). Just an FYI. I don't know if yours are like this. I might try a little heat (say 200* F) to see if that does the trick.
-T
Old Jun 15, 2003 | 06:44 PM
99f350sd's Avatar
99f350sd
axle cap removal
Thats part of the axle correct? should just come out I think there is a oring. should come out.
Old Jun 15, 2003 | 06:46 PM
kehale's Avatar
kehale
axle cap removal
Usually there is an o-ring or sealant.
I'm not sure in your case.
The bolt that I'm talking about is from the "o-ringed" end cap to the axle.
Sometimes, the hub is splined on the inside. This necessitates the removal of a center bolt.
Other axles just have end cap being part of the axle shaft.
I don't know what kind you have.
-T
Old Jun 15, 2003 | 10:31 PM
WoodN1_76's Avatar
WoodN1_76
axle cap removal
I finally discovered "tapered dowels". They are under the bolts on the axle end and I didn't even know they existed. I have all of them out on the left side, but there are two of them I can't get out on the right. The axle comes right out after they are removed, Amazing.
