Three Speed Tailshaft
Old Jun 15, 2003 | 10:36 AM
Bikeitswift's Avatar
Bikeitswift
Question Three Speed Tailshaft
I have a 63 F100, 223, 3speed (see my gallery!). New Speedo cable, new red gear, tried switching speedo, it works when drill is run in reverse on end of cable. I can feel the gear inside my tailshaft with my finger, and it is not loose and does not rotate by hand. Do I at this point driop the driveshaft, pull the (short) tailshaft off and replace the drive gear? What's involved? Is this a driveway job? Will a bearing house have that rear seal? HELP!!
Old Jun 18, 2003 | 03:52 PM
Rosati's Avatar
Rosati
sounds like the drive gear is worn out in the center. Pull the tailshaft, All you should need is some red TRV to put it back on.
