Might be a silly question
Old Aug 20, 2013 | 08:46 PM
Headviking's Avatar
Headviking
I was thinking about my park brake and how the backing plate is rusted and needs replacement for a better hold on hills. Then it hit me. Is there anyway to replace my rear callipers with a newer model that uses the brake callipers for a parking brake?
You know what I mean. Would they fit? Has anyone tried? Or is there more to it then I am realizing?
Old Aug 20, 2013 | 08:49 PM
MisterCMK's Avatar
MisterCMK
You don't want that kind of parking brake. The drum in hat is far superior IMO.
Old Aug 21, 2013 | 04:09 PM
Headviking's Avatar
Headviking
Why do you say that? I would think that the power of calliper's would out hold the drum's.
Old Aug 21, 2013 | 08:49 PM
m-chan68's Avatar
m-chan68
John, on which models did you see parking brakes integrated into the brake calipers if I may ask? As far as I know, all Super Duty trucks from '99 model year to present, all use the "drum in hat" type that our trucks have.
Old Aug 21, 2013 | 09:25 PM
Headviking's Avatar
Headviking
I thought that the new models use the calliper for the parking brake. Told you it might be a silly question.
I am just looking for an easier way to fix my park brake. I don't have a rear axle seal problem and I would like to keep it that way.
Old Aug 21, 2013 | 10:02 PM
MisterCMK's Avatar
MisterCMK
Think about the contact area of the drums versus the pads.
The parking brake calipers rotate the piston inwards which means that it is going to be more of a pain to change brake pads. It is also one more thing to stick.
It is not hard to replace the backing plates. IMO you are worrying too much about it. Go buy new seals and pull the hub. Re-install properly and you won't have any leaks.
Old Aug 21, 2013 | 11:11 PM
m-chan68's Avatar
m-chan68
When I first saw this question, I went and looked under a few 2014 model year Super Duties on our low, and they still use the exact same brake setup as our trucks.
If you ask me, changing over to a completely different rear brake setup would be a far greater undertaking than simply just removing the hub and rotor to access your parking brake parts.
Old Aug 22, 2013 | 02:58 PM
Headviking's Avatar
Headviking
You guys make a lot of sense.
Silly questions............
Old Aug 22, 2013 | 03:22 PM
npccpartsman's Avatar
npccpartsman
As always, John, there ain't no such thing as a stupid (or silly) question.
Old Aug 23, 2013 | 05:12 AM
run6.0run's Avatar
run6.0run
Here's a writeup I did on it.
https://www.ford-trucks.com/forums/s....php?t=1198326
Old Aug 23, 2013 | 03:24 PM
Headviking's Avatar
Headviking
looks straight forward enough. The spindle nut socket is that the same one used on 2007's? As well the are the the same part number for 2007?
Old Aug 23, 2013 | 03:51 PM
m-chan68's Avatar
m-chan68
Yes, in answer to all your questions John.
Old Aug 23, 2013 | 03:56 PM
MisterCMK's Avatar
MisterCMK
Amazon.com: Powerbuilt 648476 Spindle Nut Socket Special: Home Improvement Amazon.com: Powerbuilt 648476 Spindle Nut Socket Special: Home Improvement
That is what I used. It showed up at my door in 2 days with Amazon Prime.
Old Aug 23, 2013 | 07:00 PM
69cj's Avatar
69cj
No ? is stupid if we get to look at your avatar!!
Old Aug 23, 2013 | 08:47 PM
78fordman's Avatar
78fordman
Just install a microlock if you are worried about it.
