2008 E350 Van Hood Problem
Old Aug 19, 2013 | 09:10 AM
interstategar's Avatar
interstategar
I have a 2008 Ford E350 van. At highway speed the hood sometimes lifts up. Its latched and it catches, but it has play on both ends above the headlights. I've looked and can't find anything obvious that's wrong.
Anybody else run into this problem, and fixed it?
Old Aug 19, 2013 | 11:07 AM
econolinemanor's Avatar
econolinemanor
There are rubber bumpers for the side to side adjustments and lock tightness, but there's a big difference in a (lifting hood) and one that just (flutters) a little at speed. If your not sure about it find a local Body Shop and have them check it out before something bad happens............
Old Aug 20, 2013 | 05:45 AM
JWA's Avatar
JWA
Good advice from EManor---check and/or adjust the bumpers to eliminate that annoying bounc.
Does this possibly resemble the cable-operated latch releasing and only the secondary safety catch is keeping the hood in place? Or just the fluttering as you describe?
Old Aug 22, 2013 | 11:30 AM
interstategar
Its only fluttering and its not the cable operated latch. Air is getting under left and right end part of hood and lifting intermidently at hwy speed. I will work on the rubber bumpers for side to side movement and see what happens. I have a manual for 2005 E350 and will ck out where these bumbers are. Not dure exactly where they are located. Thanks.
Old Aug 22, 2013 | 11:42 AM
interstategar
Thanks! will check the rubber bumpers.
Old Aug 22, 2013 | 11:45 AM
interstategar
Ok. I see where the rubber bumpers are your talking about. Just ajusted bumpers. raised them and the problem is fixed. Thanks again.
Old Aug 22, 2013 | 03:24 PM
JWA's Avatar
JWA
Please let us know if that adjustment solves your problem---it might help others who experience or notice something similar.
Old Mar 17, 2022 | 08:31 PM
Truan's Avatar
Truan
delete this comment
LSxEconoline
May 31, 2019 10:11 PM
LSxEconoline
Feb 28, 2019 06:58 PM
75 SuperCab
Aug 27, 2006 01:37 PM
