Voltage problems
Old Jul 4, 2002 | 11:53 AM
stryder's Avatar
stryder
Voltage problems
Im stumped on this one! The voltage gauge on my '90 is only reading about 10-11 volts. I've tested the battery w/out motor running and get 13.62volts. Starting the motor and checking again, I get over 15. I've had the alt. tested and it fine. The battery is only a few months old, so Im running out of ideas??? I know this is whats causing my truck to be kinda slugish after warmup. so, any help would be greatly appreciated!
Thanks
Stryder
:-X11
Old Jul 4, 2002 | 07:35 PM
rhetor's Avatar
rhetor
Voltage problems
could just be the guage. maybe you should try testing the voltage at the guage terminals.
Old Jul 5, 2002 | 10:13 AM
winfordr's Avatar
winfordr
Voltage problems
Sounds like the volmeter you are testing with needs calibration.
It would be very rare for a battery to show more than about 12.5 volts several minutes after the engine is off. So I am thinking your tester is off. You should show between 13.5 and 14.3 volts when charging.
I always use a digital voltmeter for checking battery voltage.
Also your voltmeter gauge is probably off in the opposite direction.
Winford
Old Jul 8, 2002 | 06:22 PM
stryder's Avatar
stryder
Voltage problems
Well, Winfordr your correct. The digital voltmeter that I use was off a little. I took it over to my brother, who is an electrican, and he recalibrated it for me. It now reads 12.14V non-running/ 14.75 running. Okay, next ? How does the dash come off? I dont see ANY screws! I'm assuming they are hidden under the plastic "wood" trim, but thought I'd ask before I pry and break something. Also, if the voltage is low at the gauge, what would cause this?
Thanks a million!
Stryder
:-X11
Old Jul 8, 2002 | 07:40 PM
topo4u2's Avatar
topo4u2
Voltage problems
