2004 Explorer Drivetrain Slam
Old Aug 18, 2013 | 09:27 PM
MitchPeters's Avatar
MitchPeters
My '04 Explorer started making a noise like slamming in and out of gear. Felt and sounded like the transfer case was slipping or jumping teeth. Turning slow in gravel the left rear would drag like a spider gear problem.
It has the Auto 4x4 system, Auto-4H-4L.
I pulled transfer case out and apart. No signs of teeth missing, slipping, nothing. Chain looks good, bearings good. Clutch pack good. No sign of any metal shavings in the case.
Pulled rear differential, one bad spider gear for the left axle is all I found. Not enough for the very hard slamming it was doing.
U joints & axles good also.
Any ideas?
Old Aug 18, 2013 | 10:07 PM
shorod's Avatar
shorod
I was going to question u-joints. You mention they are good. How did you confirm they are good?
-Rod
Old Aug 19, 2013 | 01:13 AM
MitchPeters
No Movement in neutral. Both are on the floor along with rear axle shafts. Noise way worse than a u-joint
Old Aug 19, 2013 | 06:48 AM
shorod's Avatar
shorod
I wonder if it's an issue with a sensor somewhere that is making the transmission think it is under more load than it and firming up the shifts. I recall a parameter in the scan tool for "harsh shift requested" with a Yes or No response. It would be interesting to see what yours is showing.
-Rod
Old Aug 19, 2013 | 05:39 PM
sandrat's Avatar
sandrat
Sounds like a solenoid body in the transmission. There was a bulletin for this concern, did a lot of them back in the day. Especially bad in reverse? There's a delay, and then it drops in really hard?
Old Aug 20, 2013 | 09:44 AM
MitchPeters
Replacing differential first. Bad side gear and pinion play.
Old Aug 26, 2013 | 09:57 PM
MitchPeters
Differential replacement fixed the problem.
Old Aug 27, 2013 | 06:44 AM
shorod's Avatar
shorod
Glad to hear you got the problem fixed. Thank you for following up.
-Rod
ndreb
May 4, 2017 06:04 PM
txpointman
17
Oct 28, 2010 03:05 PM
4x4Hokie
Feb 6, 2009 10:27 AM
moneycoach
Oct 19, 2004 03:38 PM
