Bending beams
Old Aug 18, 2013 | 06:42 PM
devino246's Avatar
devino246
Originally Posted by blue04.5
Looks like no one there had seen it done before either that or is a govt job.
I was thinking the same thing
A good heavy truck shop should have the equipment to bend the beams. If I saw a shop trying to bend mine with a bottle jack and a chain, the manager would get an ear full. If a truck with I-beams comes into the shop for an alignment and the camber is off, the customer gets an explanation and is sent on his/her way.
Old Aug 18, 2013 | 06:46 PM
rogue40's Avatar
rogue40
Yes, I have seen very good results from using the chain down method.
All right guys, go ahead and make this as complicated as you need to.
Old Aug 18, 2013 | 06:54 PM
devino246's Avatar
devino246
And I can remove and torque the lugs on a one-ton with a pair channel locks, but it's the wrong way to do it, uses the wrong tool, can cause damage to the vehicle, and could lead to injury. Use the right tool for the job. A chain and bottle jack is not the right tool.
That's not to say you couldn't make a fixture for beam bending. I wouldn't be using chain though; 3/8" plate would be more like it.
Old Aug 18, 2013 | 08:15 PM
jim collins's Avatar
jim collins
What's complicated about passing a couple of shops that can't do it right and pull in to one that knows how ? I live way out in the farm country and can drive 15 miles north or east to a couple of small towns ' 20,000 pop. 'and pull in to a shop that can do it. Or go another 20 miles and find 3 or 4 in a larger town. So , what's complicated about that ?
Old Aug 18, 2013 | 08:52 PM
TexinCali's Avatar
TexinCali
I am in the same boat, love the Autofab solution but don't want that much lift or expense and although I have not talked to them they only list 1/2 ton kits on the web site.
I would love to get 1.5" - 2" on the front of my F350 SC!
If you find a shop that can do it in the San Diego area let me know!
Originally Posted by Broncobobby76
i have a 2wd 76 super cab f150. I am currently running 33 red labels on stock suspension. Everything clears, however it is time to lift the front a little. I have been looking at the auto fab stuff and I know it is great, however I really don't want to pull the beams and switch everything out. The beams I have now are nice and tight and the brakes and bearings are all new. When I lifted my 86 ranger a 100 years ago, I just installed a 6" coil and drove (carefully) to an alignment shop in el cajon I believe (I think it was north county alignment). They put the truck on the rack and bent the beams as necessary. This was back before everyone used longer radius arms as well. That truck worked great, and it seems like I could do the same thing here. Am I missing something?
Old Aug 18, 2013 | 08:57 PM
bighatchy's Avatar
bighatchy
You might accomplish that just by putting new springs if they're old
Old Aug 18, 2013 | 11:24 PM
Broncobobby76's Avatar
Broncobobby76
You can bring the front up a little by installing firstone bags into the coils. I currently have those. Basically to firm up the ride. I run about 40 pounds of air, which gives me about 1" of lift (on a 1/2 ton). It helps with the ride but you can visibly see the alignment is off, even though it drives nice. Very controlled at 65 or 70.
Old Aug 18, 2013 | 11:31 PM
76Hauler's Avatar
76Hauler
the shops called East County Alignment, on Mission Gorge rd.
to the OP, swapin out beams and isn't too bad, Autofab uses new pivot point bushings, and kings pins aren't too tough. their 3" econo lift would be perfect for 33's, and you wont need radius arms, although they do make a nice upgrade for steering feel.
Old Aug 18, 2013 | 11:37 PM
76Hauler's Avatar
76Hauler
other shops will chain the beam, than bolt on a long "pry bar", heat the beams, and then use leverage to bend the beam to the desired degree. sketch-tastic! but it gets the job done. Autofab uses a 100-ton press
here's some info on my truck... pm me if I can help any
https://www.ford-trucks.com/forums/9...-2wd-f250.html
Old Aug 19, 2013 | 06:59 AM
Broncobobby76
Thanks 76 hauler,
East County Alignment..."that's it"
I have been looking at your 76, in fact it comes up when you do google searches for lifted 2wd old fords. The stance that yours has is what I'm looking for. Now you listed yours as a 4" lift, however when I visit the auto fab site it offers a 3 (econo, no radius arms) and a 5 which does use longer radius arms. Would yours be what they consider the 5 or 3, or is there a 4 as well?
Old Aug 19, 2013 | 10:33 AM
76Hauler's Avatar
76Hauler
I had the 5" coils, but with the heavy 460 and full sheet metal (no fiber glass hood or fenders) John at autofab said it would lift it up 4". After the engine build using aluminum heads, and ditching the front bumper, she popped up about an 1" or so. I went ahead and did the longer radius arms, and glad I did! Adding caster took away a lot of bump steer. The 3" would be perfect for 33's, she'll look beefy.
Old Aug 19, 2013 | 11:01 AM
Broncobobby76
Thanks for the info. I'm really having a hard time deciding which kit, or to do it myself (having east county work the beams on the truck).
Old Aug 19, 2013 | 03:35 PM
  #28
montana_highboy's Avatar
montana_highboy
Originally Posted by lbcarguy
Here is what it looks like:
Must be government work...no less than seven guys standing around watching one piece of machinery do all the work....god bless America
Old Aug 19, 2013 | 05:11 PM
  #29
jim collins
Probably newbies that have heard of but never saw it done since the beam axle is a thing from the past.
Old Aug 19, 2013 | 06:35 PM
  #30
blue04.5's Avatar
blue04.5
Great minds think alike I guess
