Weird issue for me
Old Aug 17, 2013 | 08:53 PM
AjRanger88's Avatar
AjRanger88
Weird issue for me
Hello guys and gals. I have a odd issue that I myself have never encountered and am in the need of assistance with.
1989 Ford F-150 5.0 Auto 2WD
Slightly rough idle, misses through driving range and has a vibration at low rpms while driving.
this issue spurred up all of a sudden. I pulled plugs and #8 was black.
Did full tune up, plugs, wires, cap, rotor, changed coil, fuel filter, and same issue. When I changed fuel filter, it was quite clogged but not to awfully bad. I cleaned front tank before seeing as how i replaced the in tank pump when I bought the truck two years back, so I am unsure why the fuel was so dirty. Rear tank is in-op.
Next I ran a fuel system cleaner and cleaned throttle body but still came up with naught.
today I have ran all self checks, and came up with a PIP sensor code of 211. I then have ran the gauntlet of system checks and cannot find anything that is out of range on a VOM. Went ahead and pulled distributor to make sure PIP was grounding OK, cleaned everything up and put back together. Checked timing ( yes i unhooked SPOUT ) and still have the same issue, ran self checks one more time for fun and cam up with ETC out of range ( code 21)
I have checked every sensor I can think of, would list them all but my head would spin from abbreviations. Any help would make me eternally grateful this is my daily driver.
Old Aug 19, 2013 | 11:02 AM
subford's Avatar
subford
You say the timing stays the same with the SPOUT in or out.
That may be an open wire between the ICM and computer.
If not I would open the computer and see what it looks like inside.
I would change the PIP (stator) in the distributor if you got a code for it.
But you should have 2 digits codes so the 211 does not sound valid.
The 21 code may have been a cold engine.
You can not have two digits codes and three digits codes on the same truck.
kc135cruechief
Electrical Systems/Wiring
45
Dec 2, 2017 11:22 AM
87thhunter
17
Mar 6, 2016 01:15 PM
Demolishus
24
Aug 24, 2012 01:34 PM
76250_4x4
33
Jan 18, 2011 07:52 PM
crankyyank
Aug 24, 2006 03:35 AM
