Sponsored by: Kumho
Shackle Inversion
Old Jun 14, 2003 | 02:42 PM
nbaff's Avatar
nbaff
Shackle Inversion
Just got back from the junkyard. Got a pretty good deal on some rear leafs. My have two cracked leaves and were pretty rusty. I got the leaves, u-bolts, plates, blocks, shackle, front mount and rear mount. For both sides. I am seriously looking into lifting my truck. I have everything I need to do the Shackle Inversion but does anyone have any specs on it. I would just like to get it right the first time and not have to mess with anything. Thanks for the help.
Nick
Old Jun 14, 2003 | 03:31 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Shackle Inversion
Except for getting the rivets out, the shackle flip is easy. The rear spring hanger needs to bolt on 180* from it's stock orientation. Also the holes in the frame and bracket need to be drilled out to accept 1/2" grade 8 bolts. If you need a pic of what the insalled brackets look like, let me know and I'll e-mail you a one.
Old Jun 15, 2003 | 10:20 PM
nbaff's Avatar
nbaff
Shackle Inversion
Well I am in the mist of working on it right now. But it seems as though it is going to lift it too much.
Here is the question:
Can i run the rear suspension with out the block?? Seems like I could since it doesn't have any offset and it isn't anythng soft or the like. Whatcha think?
Nick
Old Jun 16, 2003 | 05:08 PM
gdavis2265's Avatar
gdavis2265
Shackle Inversion
I drew it all out in AutoCAD, seems that it would lift it too high if it were flipped 180° - i think if you turned it 180 and just used the two lower holes in the frame and used a piece of angle under the frame to catch the other two holes it would work. I can send over a pic if you send me your email address- gdavis@rahco.com
Old Jun 16, 2003 | 06:29 PM
RockinWagin's Avatar
RockinWagin
Shackle Inversion
I would appreciate those pics. Can you flip on front too? This will be on a 75 F150.
dwm@dwmillspc.org
Thanks, Don.
Old Jun 16, 2003 | 06:38 PM
gdavis2265's Avatar
gdavis2265
Shackle Inversion
no, actually I drew up some longer shackles for the front
made a .dxf drawing out of them and used a computer burn table to make the parts out of 3/8" plate - If somebody can tell me quickly how to post a pic on this board I do it.
Old Jun 16, 2003 | 07:11 PM
gdavis2265's Avatar
gdavis2265
Shackle Inversion
O.K. - If you check my gallery to the left, I have put up pics for the lift kit in there.
Thanks
Old Jun 16, 2003 | 09:23 PM
RRMike's Avatar
RRMike
Shackle Inversion
Old Jun 16, 2003 | 10:38 PM
77'F-150Mudder
Shackle Inversion
I just finished my flip today. Using the method I described, I picked up 2". This was reusing all existing holes and rotating the bracket 180*. This was actually 2" less than I was expecting. I did the shackle flip so I could get rid of the 4" blocks I got with my 6" lift kit. The truck now sits 2" lower in the rear than it did with the blocks. Needless to say, I'm a bit dissapointed as I was expecting 4-5". Basically I was expecting it to come out roughly the same ride height that it had before I removed the blocks and did the flip.
Here's what mine looks like now.
If I were to relocate the brackets the way gdavis2265 drew up (nice drawings by the way) then I believe i'd be right around 4-5".
Obviously, there are a few variables here such as the condition of the springs and such. Mine are probably shot.
I want to get rid of the factory blocks too so I think I'm making a trip the spring shop tomorrow to get some new leafs made since my flip didn't come out right. I was hoping to get off cheap for now.
Old Jun 17, 2003 | 09:13 AM
gdavis2265's Avatar
gdavis2265
Shackle Inversion
Thanks Scott, too bad you could'nt just buy a longer link that goes between the hanger and spring.
Old Jun 17, 2003 | 11:53 AM
77'F-150Mudder
Shackle Inversion
I suppose I could do that, but this gives me the excuse I need to get some leafs made that will eliminate ALL the block out back. I just dropped off an old spring this morning for the shop to work from.
Old Jun 18, 2003 | 01:45 PM
nbaff's Avatar
nbaff
Shackle Inversion
Well i did it. Looks like I am going to have to order some huge lift springs for the front. I am sure that i have gotten atleast 4 inches of lift with what i did. I used the front hanger braket from a similar year ford truck and mounted in the rear and that was used to the inversion. I don't knwo how much lift i have because i didn't take any measurement. I have a huge rake right now. can anybody tell me the distance between there axle and the frame, so that i can have some idea of how much lift i have. Mine measures 15.5 inches right now. also i left out the rear stock blocks. My truck would be on it's nose if i did. thanks.
Old Jun 18, 2003 | 09:42 PM
nbaff's Avatar
nbaff
Shackle Inversion
nobody knows? you have to have a measuring tape?? com'n
Old Jun 19, 2003 | 10:26 AM
okiebronco's Avatar
okiebronco
Shackle Inversion
i could measure mine but it wouldnt help you since its not stock
Old Jun 19, 2003 | 10:33 AM
RockinWagin
Shackle Inversion
Just subtract your pre-install measurements from the post-install measurements............... Comapring to someone elses truck will be inaccurate--age, loads, sag, etc. different. I am picking up a '75 4x4 f150 (sight unseen) this weekend and can measure then (assuming it is still stock)
